Question about Kubota Garden
Kubota m126gx meaning of fault codes r44,r42'r38
My 3560 tractor keeps displaying engine error p2414, what does that mean?
The code means your EGR valve is overheating. Attached is a link that discusses this and potential fix/solution for you.
Engine Error Code Page 3 OrangeTractorTalks Everything Kubota
Semper Fi,
Z
Jun 13, 2017 | Garden
My 3560 Kubota tractor keeps displaying a p2414 code, what does that mean?
2nd attempt to answer. EGR valve overheating.
Refer to following link for discussions.
Good luck.
Semper Fi,
Z
Jun 13, 2017 | Kubota Garden
I have an error code C56 on my kubota m 100 gx. What does that mean
You have been a very, very naughty boy and not had your machine serviced by a qualified Kubota maintenance centre.
Oct 18, 2015 | Kubota Garden
On my Kubota M135X the error code r38 appears what is the problem
What are you doing when that error code appears?
Jul 27, 2014 | Garden
ERROR CODE R38
What will the machine not do could not find that code
Feb 13, 2014 | Konica Minolta Magicolor 4690MF...
R38 Open Circuit what is value
What do you mean?
Its a low power PSU to use at modern board, 500W should be the minimum requirement for todays board!
Dec 10, 2010 | Antec SL300S 300W Power Supply (045176)...
18 volt supply too low. resistor R42 burned. Q20 not installed. schematic shows 4700 ohm resistor with Q20 installed. What value if Q20 gone?
I would fit the same type, unless the schematic shows a change, which clearly it doesn't. However I would be surprised if R42 burnt up alone! Look at the schematic, is R42 linked to any other transistor or part? If so check them if you can.
By the way is R42 a fuseable resistor, for example is the symbol on the schematic or on PC board different to most other resistors?
Feb 18, 2010 | KLH ASW10-120 Subwoofer
Garden Logo
76 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
