Why is mars red
What make it red
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Gentlemen, I have a GE P547BS fan motor.I'm trying to replace it with a Mars 10584 fan motor.
You can check the colors on the wires with an ohm meter to find there function. Highest resistance is low speed lowest resistance is high speed the one left is medium.
Aug 25, 2015 | GE Heating & Cooling
I ORDERED JOE BONAMASSA'S 2CD MUDDY WOLF AT RED ROCKS ON MAR 23 WITH A QUOTED DELIVERY OF MAR 27 - APRIL 17
sorry but we are not in the selling business contact the right people and ask them .
Apr 22, 2015 | Computers & Internet
I need to now facts about mars now!
Mars is the fourth planet from the Sun. Named after the Roman god of war, and often described as the "Red Planet" due to its reddish appearance. Mars is a terrestrial planet with a thin atmosphere composed primarily of carbon dioxide.
Cohaagen will not turn the machine on, or he risks losing control of Mars. When the machine comes on, a hot reactor penetrates into an underground glacier, sending huge plumes of oxygen into the Martian atmosphere. This produces a blue sky on Mars, which coincidentally was a feature the memory scientists at Rekall INC were going to put into Quaid's memory during his visit.
which mars are you referring to is it Mars-22 car alarm
http://www.caralarm.com/manuals/MARS/MARS-22.pdf
or some other model like the mars 32 or mars 33
http://www.caralarm.com/manuals/mars/mars-32&33.pdf
or the planet mars
hopefully I have provided the correct model number above
Mar 18, 2015 | Mars Vehicle Parts & Accessories
Car had been sputtering and stalling while stopped in "drive". Mechanic mentioned to change the thermostat so I did it myself. The problem still exists and now the blower for the heat and A/c doesn't
  • Doug Warne Your kia here is what i would do to help diagnosisMar 19, 2014
  • Doug Warne First of all i would do these steps"
    Mar 19, 2014
  • Doug Warne how does it run when cold how does it run when hot
    Mar 19, 2014
  • Doug Warne i would look for Vacuum Leaks
    Mar 19, 2014
  • Doug Warne i would remove the spark plugs check engine compression hope to see about 180 psi on each cylinder
    Mar 19, 2014
  • Doug Warne i would exam each spark plugs to see if fowled with Gasoline or carbon keep spark plug with each cylinder because low compression will cause this
    Mar 19, 2014
  • Doug Warne low compression i would exam cooling systemicon1.pngfor airbubles or coolant in engine oil
    Mar 19, 2014
  • Doug Warne if oil looks milky white in color its coolant do not operate vehicle
    Mar 19, 2014
  • Doug Warne change head gasket get head kit with valve cover and take head to machine shop to have shaved straight and checked for cracks Replace head with Remanufactured if warrpiage to great or stress cracks
    Mar 19, 2014
  • Doug Warne check air filter and breather to insure the intake is getting air before you do compression test
    Mar 19, 2014
  • Doug Warne if engine dies when hot lets look at the fuel pump pressure
    Mar 19, 2014
  • Doug Warne lets take and look at the fuel cap where you put your fuel in make sure the vent is open which allow outside air pressure becuase you can have a 100 billion gallon second pump but if there is no air coming into take the pump will pump 0
    Mar 19, 2014
  • Doug Warne Check your OBD 2 codes First this will give you ideas of what happening ie bad oxgen sensor telling me look for vacuum leak or poor spark ignition or poor engine compression, possible injector leaking
    Mar 19, 2014
  • Doug Warne poor compression tell me the engine maybe out of timing and or valves or worn or burnt exspecially when engine is hot and it dies
    Mar 19, 2014
  • Doug Warne a cylinder leak down test would be revealing for valves or piston rings
    Mar 19, 2014
  • Doug Warne if engine has good Intake of Air and gas mixture and then good compression of air and gas mixture and good spark from the Ignition and good flowing exhaust the engine will operated smoothly
    Mar 19, 2014
  • Doug Warne if engine looses power or stalls when hot take a look at the catyalitic converters to see if glowing red or hot one side and cooler on rear side also check the exahust pessure at tail pipe to see if cats are plugged if you have little exhaust pressure and no exhaust leaks
    Mar 19, 2014
  • Doug Warne i hope this helps and i always kiss the job.............
    Mar 19, 2014
  • Doug Warne Keep IT Simple Stupid
    Mar 19, 2014
    Mar 19, 2014
  • Doug Warne as far as the thermostat is the engine running hot..????
    Mar 19, 2014
  • Doug Warne CHECK FOR AIR BUBBLES IN COOLANT as piston compress air if it leaking pass the headgasket seal into the coolant jacket this will cause air bubbles and you may loose heat out of the heater core...i have seen this with cracked heads also so if this is the case have head checked at machine shop
    Mar 19, 2014
  • Doug Warne check the oil from the dip stick smell it see if you smell gasoline this is telling me thin oil, possible injector leaking gasoline
    Mar 19, 2014
  • Doug Warne Low engine Compression with satuerate oil the oil ring on the piston will have hard time to create seal to cylinder wall there fore low compression exspecially when engine is hot
    Mar 19, 2014
  • Doug Warne get a spray bottle fill with water and with engine runing spray water in coil packs and spark plugs wires to see if there cracked or frayed Electricty is lazy it will use the water as a ciricut and go to ground through the water this is telling me cracked coil pack or plug wires engine will began to miss and fumble while running
    Mar 19, 2014
  • Doug Warne these are some tricks i use to help diagnosis problems....hope this helps
    Mar 19, 2014
  • Doug Warne As far as the A/c Heater Blower i would first check the Fuse in the box with a test light, and i would check all the fuses remember you have a battery side and ignition side of the fuse box if the fuse is blow replace with manufacture Amp Fuse and if new fuse shorts then i would look at blower motor draw
    Mar 20, 2014
  • Doug Warne Check your battery Cold Crank Amps with a load test meter most parts store will do for free hoping you will buy a battery and if batter test not good if you choose to not to replace your alternator will be charging constentently and the trio diode board in your regulator located inside the alternator in most applications these days will short then this will cause a battery high amp draw so your battery wont start in the am when your late for work..
    Mar 20, 2014
  • Doug Warne If your battery is loosing charge overnight or anytime you can simply take your negaitive Cable from your batter and put a test light from the negiative cable then touch your neg. terminal and if test light illuminates you have a draw and bad draw so take amp meter and test to see the draw in amps if high amp draw i would first look at the regulator and remove the 12volt singe wire and see if draw disappear if draw is no longer then 99 percent your regulator has shorted
Mar 19, 2014 | 2001 Kia Sportage
I am doing a prodject on mars but I cant think of any thing
The best projects usually have a subject that is narrowed to just one aspect. Like interesting dust clouds on Mars. Or Why does Mars appear to be red. Or Successful probe landings on Mars.
Oct 24, 2013 | Computers & Internet
Mars blower motor diagram?4 wires
Gentlemen,
I have a GE P547BS fan motor. I find replace it with a Mars 10584 fan motor. GE has five wires, BRN, YEL,PUR,BLK,RED. Goes through the capacitor with the yellow going on to 200 V the purple and black go to 220 V. Mars motor as a six wire connection two Brown's go to the capacitor. yellow I'm assuming goes to the hot/neutral and a black I would say would be high-speed blue is medium and red is low. Now when I connect with this way it blows the fuse. Anybody run into this problem before? Any help? By the way, it's a 240 V single phase system.
Jun 05, 2012 | Heating & Cooling
Catalyst 3750 keeps rebooting with an error message platform-1-crashed
Contact Cisco support for a replacement. It is not normal for a switch to reboot like that. Cisco switches (not routers)have a lifetime warranty
Mar 12, 2012 | Cisco Catalyst 3750 24 10/100 + 2 SFP...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
