Question about Sewing Machines
Bobbin thread is gathering up under Neath - Sewing Machines
  • Sewing Machines Master
  • 11,474 Answers
Sounds like birds nest or thread nests. HINT: When threading the top thread, ALWAYS have the presser foot in the RAISED position.
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Posted on May 10, 2017
Please check your fabric results. Is it the bobbin thread that is accumulating under the fabric, or is it really the top thread that is globbing and knotting under the fabric. Usually, thread mishaps under the fabric are the result of an issue with the top thread.
ALWAYS RAISE the presser foot when threading the upper thread. This releases the tension disks so the thread will seat properly. Use a brand new needle. Start out with the upper thread tension set midway between high & low numbers, although this can be tweaked.
If it is in fact the upper thread, then here are some suggestions:
Troubleshooting Thread Nesting Sew Toot
Nov 29, 2016 | Sewing Machines
Machine will not sew its is looping under neath from top cotton
Remove the upper thread from your machine.
RAISE the presser foot and then rethread from the beginning. Raising the presser foot releases the tension disk so the thread will seat properly). Also, verify that the threading steps are correct (consult the threading instructions).
Check that the bobbin thread has been loaded in the bobbin case properly and threaded through the tension spring.
Test. If the upper thread is still showing under the fabric, tighten the upper tension disk until the upper and bobbin threads meet in the middle of the fabric.
Feb 03, 2016 | Janome Harmony 2041
Singer 144w305. Try to use reverse and the thread binds up under neath and breaks instantly. Take the belt off the machine spins free and easy by hand. Out belt back on and it is hard to turn by hand.
check the bobbin / needle thread tension.
IN most machines the reverse is just for the feed as the needle and bobbin still spin in the same direction
May 02, 2015 | Singer Sewing Machines
Having a problem with stitch tension can you help
is it just the fabric that is gathering or the bobbin thread also ?
Jan 24, 2015 | Janome Memory Craft 9000 Computerized...
How can I factory reset my PFAFF 7550 sewing machine ?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Feb 28, 2013 | PfaFF Creative 7570
Machine keeps sewing loopy under neath
change the needle
adjust the top thread tension one number or letter higher till the stitch
look better
rethread the machine top & bobbin
Sep 01, 2012 | Toyota Sewing Machines
Thread is gathering under cloth
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
May 05, 2011 | Olde Thompson PWZ500
Every few stitches thread gathers and jams on bobbin side of fabric. Why? [the machine is a Singer model 6180]
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin
Check tension 3 or 4 is usually good
Nov 23, 2010 | Sewing Machines
My machine gathers thread in the bobbin and then the thread breaks off.
check the needle to see if it's damaged
some sewing machines gather thread in the bobbin area when the thread come off the thread take up lever
check the bobbin & bobbin area for burrs
Sep 23, 2010 | Singer Sewing Machines
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
