Won't turn on no red lite - Televison & Video
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: TV won't turn on red lite is on
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
In some cases the fault can be related to faulty connections or poor soldering joints. Here are some tips to check out weak solder or heat related faults:
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Posted on Sep 15, 2011
Red lite on printer-won't print
The red light on this printer would normally indicate paper jam, a cover open or the waste toner container is full. I would recommend double checking that no small bits of paper have got themselves lodged around rollers inside the printer. Failing this I would check the status of the waste toner bottle to see how full the printer thinks it is.
This can normally be done using the printers software on the PC, but sadly I am unfamiliar with doing it for your particular machine.
Jun 05, 2012 | Samsung CLP 300 Laser Printer
Oven lite won't go off and when turn on self cleaning it says door
The door switch has gone bad. This will keep the oven light on and the self clean won't work because it thinks the door is open.
Dec 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
The problem is, there is a red lite on thaty says controls locked and it won't go off. I have tried unplugging it but the lite comes back on when I plug the washer in.
you will need to change the interface control if that is the case or if you did not try it yet there is a button on the bottom right hand corner of your control panel it says to hold down for three seconds to unlock control.
Jul 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
NDS Lite still red light
well one thing that can cause this is major damage in the charger or the ds lite
Feb 02, 2010 | Nintendo Video Game Consoles & Games
Broken
can you send me a now won
May 22, 2008 | Nintendo DS Lite Console
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Oct 13, 2007 | Filter Queen Defender Air Purifier
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
