Question about Baby Gear
I would like to buy a "Canvas" OFFSET UMBELLA NETTING
Fibres appear on canvas after painting
it is pretty obvious that you did not prepared canvas correctly, before you use your medium you need to prepare it. use gesso to even the surface of the canvas seem like you are using water based paint on natural fibers.
fibres in the canvas are picking out the water, swell and raise from the surface,
easiest way to fix this problem is to stretch well your canvas, then use flat knife or broad spatula and evenly work gesso into the working surface, wait day or two and repeat the exercise, sometime even more than twice, if you are doing showpiece which will be covered with high gloss finish, apply at least three to four layers of gesso sanding with 600grit block between layers, your artpiece will then really shine.
if you work on paper, use good quality aquarell (watercolour) or similar paper, stretch it well, pre-wash and they use your airbrush tints or paints. gesso or fixative can be used as well on paper.
if you paint on wood, you definitely need two layers of gesso, if this is very light wood - probably even more, oak and dense woods, especially well seasoned (i tend to buy wood from demolition sites and then make my own as i need) are best for the purpose, do not use planks thinner than 10mm (3/8"), my preferred is actually 20mm (3/4").
if you have any other question - feel free to ask, do not forget to rate... :-)
Jan 30, 2014 | Airbrush-Depot Master Airbrush Model G23...
Where can I find insect netting for the kool stride jogging stroller?
You should go on Amazon and type in what kind of stroller you have than put insect netting after it
Aug 31, 2013 | Koolstop Gadabout Stroller
Where can I buy a cotton canvas tent?
Here are a couple of links to places that specialize in canvas tents. http://www.canvastents.co.za/
Or http://www.canvashome.com/
Sep 10, 2012 | Camping, Backpacking & Hiking
Safetech triple jogging stroller awning
I'm having the same problem, if you have found a solution to stopping the sun please email me tips debbiemoore7@googlemail.com
Apr 08, 2010 | SafeTech Triple Jogging Stroller
Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
Jun 15, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Assembly
Here is the link to the manual; http://www.gracobaby.com/assets/pdfs/instructions/ISPP031AA.pdf Please post again if you need more help :)
Mar 28, 2007 | Graco 9445DOH Crib
Baby Gear Logo
29 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
