What do I add to USB drive, to make a working standalone version of scripts? For FilemakerPro version 4.1
Can i run utorrent portable from a flash drive on a dfferent computer
1. You will have to Download the latest version the latest standalone version, and copy it onto your memory stick.
2. Create an empty data file with notepad, and name it settings.dat
3. Place the settings.dat file in the same folder on your USB disk as uTorrent.
4. Run uTorrent from your portable drive and configure the options and preferences.
Aug 23, 2012 | PortableApps uTorrent Portable
Connecting problems
Installation
The scripts communicate with the Jandy system through a USB Serial Adaptor (e.g. the Keyspan USA-19HS USB Serial Adapter) connected to the Jandy Aqualink RS Serial Adaptor.
In order to use these scripts with SerialX, you will need to separately download and install SerialX as a Scripting Addition. As currently written, you will also need to determine the exact name of your serial connection and edit the following statement in both scripts:
property SerialConnectionName : "/dev/cu.USA19H47P1.1" -- Replace "dev/cu.USA19H47P1.1" with the name of your USB Serial Adaptor.
After editing, drag the Jandy Aqualink attachment script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Attachments
and the Jandy Aqualink background sync script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Background Tasks
Initiating use of the background script is typically accomplished by establishing a Trigger Action that activates on Indigo Server restart.
Usage
Assumes a Jandy Aqualink RS-4 or RS-8 Pool/Spa combination with auxiliary 1 set for pool light and auxiliary 2 set for spa light.
Unlike the previous version, the background script will now automatically execute periodically after being initiated (typically with a Trigger Action that activates on Indigo startup), will create variables as needed, and will update the status of those variables. By default the updates occur every 30 sec for most items using a single "#LEDS?" command, and every 30 min for the temperatures, with error detection if something does not update correctly. If the Spa is heating, temperature updates default to every 2 min. Variables created include AirTemp, ErrorFree, NextTempUpdate, PoolHeatEna, PoolHeatOn, PoolLightOn, PoolPumpOn, PoolSetPoint, PoolStateOn, PoolTemp, SpaHeatEna, SpaHeatOn, SpaLightOn, SpaSetPoint, SpaStateOn, SpaTemp.
Nov 22, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I need to enable java script on my browser
To allow all Web sites in the Internet zone to run scripts, use the steps that apply to your browser:
Windows Internet Explorer(all versions except Pocket Internet Explorer)
Note To allow scripting on this Web site only, and to leave scripting disabled in the Internet zone, add this Web site to the Trusted sites zone.
  1. On the Tools menu, click Internet Options, and then click the Security tab.
  2. Click the Internet zone.
  3. If you do not have to customize your Internet security settings, click Default Level. Then do step 4
  4. If you have to customize your Internet security settings, follow these steps:
    a. Click Custom Level.
    b. In the Security Settings - Internet Zone dialog box, click Enable for Active Scripting in the Scripting section.
  5. Click the Back button to return to the previous page, and then click the Refresh button to run scripts.
Mozilla Corporation's Firefox version 2
  1. On the Tools menu, click Options.
  2. On the Content tab, click to select the Enable JavaScript check box.
  3. Click the Go back one page button to return to the previous page, and then click the Reload current page button to run scripts.
Opera Software's Opera version 9
  1. On the Tools menu, click Preferences.
  2. On the Advanced tab, click Content.
  3. Click to select the Enable JavaScript check box, and then click OK.
  4. Click the Back button to return to the previous page, and then click the Reload button to run scripts.
Netscape browsers
  1. Select Edit, Preferences,Advanced
  2. Click to select Enable JavaScript option
Sep 12, 2011 | Computers & Internet
Skype has stopping working
Hi Julie!
To solve this problem, uninstall Skype through Add/Remove Programs (Win XP) or Programs and Features (Win Vista/7); Next, search drive C for folders named Skype - and delete them all (make sure to enable searching hidden files and folder -and- system folders!); Next, download newest Skype (standalone) version from here. Install it - and enjoy! :)
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
May 29, 2011 | Skype IM
This operation has been canceled due to restrictions in effect on this computer. Please cantect your system administrator. Do you want to continue running scripts on this page yes no
You will be able to run all executables on your desktop and will be able to open all documents on the desktop. The programs also will work but you will not be able to save any thing in any folder as it refuses to open the folder/drive in the "Save as" window.
The solution of this problem can be done by using the Microsoft Management Console to fix issues with access permissions.TGA. The procedure is as follows..
  1. Click Start > Run. Type MMC and then click OK.
  2. Click Console and then click Add/remove Snap-in.
  3. In the Add/remove Snap-in dialog box, click Add.
  4. In the Add Standalone Snap-in list, click Group Policy, and then click Add.
  5. In the Group Policy object window, click Finish.
  6. Click Close, and then click OK.
  7. Go to Local Computer Policy > User Configuration > Administrative Templates.
  8. Click Desktop.
  9. In the right-pane, Right-click Hide my Network Places icon on desktop, and then click Properties.
  10. Click Not Configured, and then click OK.
  11. Expand Windows Components, and then click Windows explorer.
  12. In the right pane, right-click Prevent access to drives from my Computer, and then click Properties.
  13. Click Not Configured, and then click OK.
  14. Quit the Local Computer Policy MMC snap-in.
Sep 14, 2010 | Microsoft Office Professional 2007 Full...
Why wont my wd elements 1 tb hardrive work on my ps3??
1) It needs to be FAT32 PLUS it needs to be externally powered. I found out the hard way that the PS3's USB ports do NOT provide enough power for a standalone USB hard drive, so you need to add your own power supply.
Dec 09, 2009 | Western Digital My Book Essential 1TB...
Every time I reboot my computer the Belkin Storage Manager adds a new network drive connection. It's to the same USB hard drive I have connected to the router. It starts a Z: drive and works back. I can...
If you're on a network, you might have a script attached to a group policy object that tells your server to create a network drive each time you log on. So you might want to check with you GPOs in Active Directory, or you might want to check with your stand-alone Group Policy by typing gpedit.msc in your 'run' window
Jun 20, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Internet Explorer error reading scripts on this page
On internet page, go to intrenet option and click on restore default, or if you rmember the last time your computer work perfectly, then go to START-PROGRAMS-ACCESSORIES-SYSTEM TOOLS-SYSTEM RESTORE.
this will help . Good luck
Jun 03, 2009 | Microsoft Office Outlook 2003 for PC
I want to execute java command through php
1. Copy JavaBridge.jar to the current directory.
Add JavaBridge.jar to your Java application. Edit the manifest MANIFEST.MF
2. Recompile your Java application.
3. Run your Java application. This time your application doesn't display anything and doesn't return.
4. Create a PHP test script.
5. Open a new command shell and run your test script.
6. Your PHP script has called the method hello(), which should display a message dialog.
7. Note that the above code doesn't create a application-modal dialog. The communication can be traced by starting your application with the options: java -Dphp.java.bridge.default_log_file= -Dphp.java.bridge.default_log_level=4 -jar HelloWorld.jar
for more read INSTALL.STANDALONE documentation
How to execute Java Programs using console command prompt
May 22, 2017 | The PHP Group PHP
Fix script page error
re-install the program internet explorer.
or go to ( On your computer ) Start/all programs/accesories/system tools/system information.
From there you should have an option to repair internet explorer.
Mike @ Compurepair.
Feb 22, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
