Question about Campbell Hausfeld Air Tools & Compressors
I have a campbell hausfeld fraiming hammer that leaks air from the nose. I beleive the model # is NS349000 or DK751200AV. Ive taking it apart and the o-rings all look good.Thanks Dan
  • 2,478 Answers
I WOULD CHANGE THE O-RINGS YOU HAVE IT APART BEST TO REPLACE WITH NEW
Posted on May 09, 2017
Campbell hausfeld problems
You have to change out the Seal and it will work fine..
Jul 20, 2014 | Campbell Hausfeld Air Tools & Compressors
Broken spring on kiddyguard
Please go to this site for parts:
http://www.ereplacementparts.com/campbell-hausfeld-parts-c-32345.html
Jan 12, 2013 | Campbell Hausfeld 2 Pc. Replacement Spring...
Campbell hausfeld 60 gallon sight glass oil leak
Try here http://www.about-air-compressors.com/campbell-hausfeld-air-compressors.html
Jul 30, 2012 | Campbell Hausfeld Air Tools & Compressors
Gun leaks
No it is not. It should not leak at all. Where is it leaking air from? The 3 obvious places are the exhaust at the top of the head, the nose where the driver comes down, and the trigger valve.
Jul 29, 2012 | Campbell Hausfeld 2-in 18 Gauge Brad...
Air leaks when triggered and no nail
Make sure no nails in gun. With air connected listen for leaking thru nose of the gun also. If leaking thru nose slightly, air is getting past the cylinder seal oring and/or top of cyl is not seating against headvalve. Repair leak to nose of gun before trying to fix head leak. With no air leaking thru nose of gun, add plenty of white grease to orings in the head (one oring at a time) to see if leak is less and/or grease will streak behind the leaking oring. Then repair as needed. May need slightly thicker oring or sand surface where oring makes contact to remove scratches that are allowing air to pass. Also air can enter the head thru the small port in the gasket leading to the head (make sure that the gasket is sealing).
Nov 05, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
My Campbell Hausfeld compressor model WL650101AJ will only pump to 80psi and will not shut off.
TAKE THE COVER OF THE TOP HAS 2 PHILLIPS SCREWS AND SNAPS OFF. THERE IS A COPPER TUBE THAT GOES BETWEEN THE COMPRESSOR HEAD AND THE CHECK VALVE TAKE THE TUBE COMPRESSION NUTS LOOSE AND REMOVE THE TUBE. CHECK THE RUBBER SEALS IF THEY ARE MISSING OR TORN YOUR COMPRESSOR LEAKS WHEN IT IS RUNNING BUT IF YOU SHUT IT OF THERE IS NO AIR IN THE PIPE SO CHECKING IT WITH IT OF WONT DETECT THE LEAK. MY COMPRESSOR WAS DOING THE SAME THING AN THIS FIXED IT.
Jan 26, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
16g wont shoot nails. bottom flat piece comes out
You broke the "hammer" you can open the housing and replace it, fairly simply. You can buy replacement parts at most large scale hardware or tool stores. The task takes about 10 min, and some simple hand tools.
Jan 03, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
Where can I get nails for this nailer?
You can buy it from any Campbell Hausfeld dealer in
your area.
Oct 13, 2009 | Campbell Hausfeld NB0064MVRB NA 2-1/2"...
Campbell Hausfeld NS2190MVRB 21 Degree Round Head Framing Nailer is jammed. How do I clear it?
Remove any nails in the magazine, and you can carefully take a pin pinch of a size that fits into the nose (where the nails come out). Try to carefully tap the driver back into the gun.This will sometimes clear the jambed nail. If the driver is severely jambed you will have to dismantle the entire unit to separate the driver from the nose of the nailer.
Mar 24, 2009 | Campbell Hausfeld Tools & Hardware -...
Air Tools & Compressors Logo
49 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
