Question about Boating
What year is a merc 4 stroke R358842 - Boating
I have a 90 hp merc starts great but misses over 13 00 rpm 4 stroke any ideas ?
SOUNDS LIKE YOU HAVE A PROBLEM WITH THE CDI POWER PAC.THEY HAVE AND OVERHEAT MODE THAT WILL ONLY LET THE ENGINE RUN AT LOW SPEED SO IT DON'T RUIN THE MOTOR AND THEY DO GO BAD.
Jan 20, 2018 | HP Boating
NEED IMPELLER KIT PART # FOR 2.5 LITRE V6 2 STROKE SERIAL NUMBER OD145403
available from any merc outboard service shop
if there is none close , the kit may be generic so mariner pump may fit
talk with outboard shop spares
Nov 15, 2017 | Boating
I have a merc 40 hp x 4 engine starts and runs fine but every 20 to 30 minutes it decides to just stop dead after a few minutes it runs fine again,
this is HP computer forum , not BOATS
but can answer ,
bad fuel!! all boat fuel goes bad, parked, so long, ALL DO.
too much oil in fuel (is it 2 stroke engine? no year given,so.,....)
carb, filthy, im cleaning my 40 hp now, in the garage, and wheel grease.. (fishing next,cat fish... hummm)
can be bad spark plugs. ever tune it up. with new ones?
water in fuel. rust in tank if tank is steel.
wrong fuel someone put in diesel
low compression (3 cylinders like mine?)
May 25, 2017 | HP Computers & Internet
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
What is the correct timming on a 2000 merc 50hp 2
it is a preset thing that requires no setting .
Mar 12, 2010 | Boating
Boating Logo
29 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
