Question about Apple iPhone Smartphone
Pairing headset ive been trying to pair my jawbone headset to my iphone butit wont pair what are the steps or why is it not pairing?
Re: pairing headset
You need to have the manual for hour jawbone headset and follow those instructions.  You have to put the headset in "pairing mode" and then once you do that (follow headset instructions) it's simple to just go to settings, bluetooth and tell iphone to search for the headset.
Instead of headset issues, we're having car speaker phone issues.  I have the iphone paired with a motorola bluetooth car speaker, and it works when you are making calls.  However when a call comes in, the speaker doesn't pick up, the phone just rings as normal.  That's a problem as you need to be hands free in our state, and if a cop happens to see you, you're in for it
Posted on Nov 22, 2007
0 characters
3 Points
Jawbone won't pair with iphone
Hi, you need to plug the jawbone to a computer in order to connect it for the first time to your phone, it can also be an issue with your phone bluetooth, restart might solve it.
Feb 17, 2014 | Apple iPhone Cell Phones
My samsung i7500 doesnot work well with my Jawbone bluetooth
Sometimes I find that de-pairing my bluetooth headset from my phone and re-pairing it helps when things are working like they should. Follow the steps in the manuals for both your phone and headset to make sure everything is connected correctly.
Mar 04, 2011 | Samsung I7500 Smartphone
How do I pair my jawbone icon with HTC evo phone
From your main/home screen :
1. Press your "Menu" button. ( located near the bottom of your phone to the left of your home button )
2. Press the "Settings" button.
3. Press the "Wireless and Networks" button.
4. Check the Bluetooth box to turn on bluetooth.
5. Press the Bluetooth Settings button.
6. Put your Jawbone Icon into discoverable mode. Follow this link for instructions if you cant find your manual.
7. Click "Scan for Devices" on your EVO.
8. When your Jawbone Icon appears in the Devices list click on it and pair the devices. At this point it will ask you to accept pairing. Once you do that you should be good to use your headset.
Feb 28, 2011 | HTC EVO 4G Smartphone
How do i pair my jawbone bluetooth headset to my envy touch?
I found this on another website and it worked for me.
"I was also having a lot of difficulty getting my Jawbone II or "new Jawbone" into pairing mode. I finally ended up carefully removing the outer plastic shield. It popped off without breaking anything and then I was able to easily press BOTH the noise shield button AND the talk button. With the plastic cover OFF, I was able to put my Jawbone into pairing mode on the FIRST TRY!"
Jan 19, 2011 | LG enV Touch VX11000 Cell Phone
Have a jawbone bluetooth ear piece trying to pair it with a blackberry cant remember how to pair it
I have two jawbone headsets and they won't pair with our blackberry phones. Can you help me
May 20, 2010 | Cell Phones
My Jawbone headset will not pair with the iphone 3g, even after going to settings-general-bluetooth. The iphone keeps serching for a device but cannot find it.
1. Settings
2. Bluetooth
3. Turn Bluetooth ON
4. Make sure your Jawbone is OFF
5. Press TOP Of Jawbone & MIDDLE of Jawbone TOGETHER Until It Flashes Red & White
6. JAWBONE Will Come Up On The iPhone
7. Pir The Device With iPhone
8. Enter Four Digit Code
9. 0000
Thanks to Sally Jo for this tip!
Dec 31, 2009 | Apple iPhone 3G
Lg env v pairs with jawbone but won't connect. is it the code?
I have had the same issue with MY Samsung bluetooth headset.
Here's the sequence that works for me:
  1. Delete the headset under the bluetooth menu.
  2. Turn off the bluetooth
  3. turn on the blue tooth
  4. Add the headset back. The default pair code for most devices is "0000" or "1234"
  5. Try to enable/connect. If it fais, simply power off the enV.
  6. Power on and try to connect again (just connect, not pair)
  7. Headset will then pair.
KingGypsy in Phx.
Jan 19, 2009 | LG enV VX9900 Cellular Phone
Bluetooth headset static
BOOHOO - The phone needs to be diagnosed to determine the issue so take it to a mobile service center
RLECANDAR - from my experience the JAWBONE is an awful headset most customers that buy then replace them with another headset
May 22, 2008 | Samsung SCH-u740 Cellular Phone
With use of Jawbone, recipients on enV get voice echo
About three months ago I bought the LG En V touch from a verizon store. I planned to use it with my old "New Jawbone" and my new "Jawbone Prime". The phone would nto pair at first then when they finally got it to pair I had a variety of problems. Verizon technicians performe a number of different steps trying to make it work as it was supposed to. They even reinstalled the software after about a week and a half I persuded the Verizon stor manager to replace the phone with a new LG EnVtouch and they exchanged my Jawbone Prime also. The new LG EnVtouch had the exact same set of problems. Neither of these phones worked any better with the bluetooth in my Garmin NUVI either. I loved the design and the features but if it doesn't work why bother. I returned the second LG EnVtouch after aabout five more days of frustration. And went back to my old phone. If you buy one of these and it doesn't work return it fast and let them know what you think!
Apr 20, 2008 | LG enV VX9900 Cellular Phone
Iphone and headset
Is this the first time you're pairing iPhone and jawbone or it's been working before?
If this is the first time,
1. Go to settings-general-bluetooth and turn on the bluetooth on your iPhone 2. Press and hold the button above the LED light until the LED light flashes Red and White 3. Go to your iPhone and click on Jawbone and it should connect.
If it's been working before:
1. Make sure Jawbone is fully charged. 2. Press and hold the button below the LED until white light blinks 3. Go to iPhone make sure bluetooth is on press Jawbone to connect
If this procedure fails try the to follow the First Time Pairing Instruction
Hope this works for you.
Nov 21, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
465 people viewed this question
Top Apple Cell Phones Experts
Barrett Palumbo
Barrett Palumbo
Ed Nelson
Ed Nelson
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
