Question about Crafts & Hobbies
The cordnate plane,extend - Crafts & Hobbies
Do airplanes use a key to start?
Depends on the plane. Most small general aviation planes use a key. Larger planes, and commercial airliners do not. The owner of the plane keeps the key with them and in many cases is required to have a secondary locking system of some sort on the plane.
Jan 04, 2017 | Aircrafts
Adjusting stanley block plane G12-060
Adjust the mouth opening by loosening the front knob, then turning the little lever under it to move the sliding "tongue". Adjust the iron extension by turning the rear knob - it should BARELY peek out under the sole. Adjust the iron\'s angle by sliding the rear lever from side to side. Adjust the iron\'s tension with the top cap screw.
As you plane, if your plane takes off anything thicker than a single layer of toilet paper, the iron is extended too far. A block plane is not a tool to take off big hunks of wood, it\'s a tool to very slightly shave a wood surface, one thousandth of an inch at a time. As such, it needs to be crazily sharp, sharpened to your best approach to perfection. Please read about "Scary Sharp" on the Internet.
Jan 15, 2014 | Stanley Crafts & Hobbies
How to adjust
Those are funny little planes - they're wicked handy when you need one. I like mine a LOT.
They ARE coarsely built, not a "fine" tool, but they do a fine job.
Loosen the little screw SLIGHTLY, then either bump the rear of the iron (to extend it more) or the rear of the plane (to extend the iron less) against a piece of softwood (bench, sawhorse, 2x4, hammer handle). When it's where you want it, tighten the little screw again.
Adjust the plane's mouth (assuming that you're using it as a bullnose plane, not as a chisel plane) by loosening the big screw, then just sliding the bullnose front & rear.
Remember - planes are meant to SHAVE wood. The iron should NOT take off a thick shaving, it should take off a shaving no thicker than one sheet of toilet paper. The iron should BARELY peek out from under the plane.
Jan 14, 2014 | Stanley 12 - 975 Contractor Grade Bull...
What Add2 card will fit in the HP 5700 small frame factor?
I understand that you want to add a second display to the
HP Compaq dc5700 Small Form Factor PC. I had checked and found that the Video adapter features RAMDAC integrated (400-MHz); Controller Clock Speed: 667 MHz; Overlay Planes: One 16 bit video overlay plane; Max Color Depth: 32-bits/pixel; Multi-display Support: Support for one VGA and one DVI-D, in conjunction with an ADD2 card, clone and extended desktop modes are supported. It specifies that the clone and extended desktop modes are supported. You may try connecting the second display and check the operation. Also the computer comes with the expansion slots 2 low profile PCI, 1 low profile PCI Express x1 and 1 SDVO/ ADD2 connector. You can go for a video card that can be connected to the PCI slot.
You can refer the link from Micrsoft for the information to How To Configure and Use Multiple Monitors in Windows XP
Nov 18, 2013 | HP Compaq dc5100 PC Desktop
Broke 4 belts in 3 months
Check to see if your pulleys are all in the same plane. Take a ruler or other straight edge and put it on the front of one pulley and then extend it to the nearest pulley and make sure that the line up. Sweep the straight edge over the next pulley while holding it firmly on the first pulley to verify that they are both on the same plane. Repeat with all pulleys.
Apr 05, 2013 | Dryers
How do I plane the edge, end and surface of a board? how do i find a hand saw for ripping a board?
Are your arms big? Good, cause that is how you do it. With a lot of muscle. They have too many power tools out there now to make it easier. But if you want to do it the old way, you will need a handful of planes, not just one block plane. You need a couple of jack planes, smoothing plane, and scraper plane, to get a nice surface, the jack plane, 12 -14 inches long will go right over the bumps and flatten those edges right out, Keep it square to the edge. Look by eye and use a square to check. Your end grain can be done with your block plane, get it in a vise and take little cuts. Your surface is the tough one, it takes a sharp iron and a steady hand to surface a board, some woods don't like being surfaced, some do. Again, start out with the scrub plane, 8-12 inches, and run it against the grain to smooth, then the jack plane with the grain to flatten, then the scraper to finish. Rip saws are hard to come by, the teeth are at a 90 degrees to the saw. and wide, and you need big arms. The japanese saws have both edges on their saws and they work great. But you can't beat an electric planer. Hope this helps.
Apr 06, 2010 | Craftsman 7 in. Plane Block
Cannot shut it off permanently
Turns out (IN OUR OPINION)
That letting the watch run is far better than turning it off.
Due to battery draining over time, and Just fact that if its not running for an extended amount of time it may not restart.
If planing to leave it inactive for extended time have the battery removed if not just let it run.
Hope this tip helps.
Have had numerous customers come in and have battery changed in a watch that was working fine. stopped the watch and the watch would not restart. (Just our humble observation).....
R/
David
Feb 18, 2010 | Avalon Ezc Voice Series Low Vision Talking...
The mouse works perfectly find outside my games but once you move into the game and to move your crosshair to aim it jumps rather than smoothly scroll in the direction you move
dear sir
good day
try to do celebration for the mouse agine frome
the setup or the program come with the mouse
to fix up the cordnates for the cross hair
thank you
Dec 24, 2009 | Microsoft SideWinder Mouse - Mouse - laser...
Crafts & Hobbies Logo
350 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
