Question about Cell Phones
  • 52 Answers
SOURCE: sgh p310 wont charge
Please check your charging port if the pins are still OK. Please also try a new charger. Perhaps your charger is already defective.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Posted on Dec 31, 2008
  • 221 Answers
SOURCE: Motorola W375 won't charge online!
You'll need pc charging drivers to charge your phone with a pc and a USB cable, you can get the driver at the motorola website.
hope this helps.
Posted on Mar 31, 2009
  • 37 Answers
SOURCE: my GE 5/8 GHZ phones will not hold a charge.
The battery of the phone may need to be replaced. The lifetime of a cordless phone battery in 1 year...depending upon the usage.
Posted on Apr 30, 2009
  • 32281 Answers
SOURCE: Toshiba A205 won't charge unless I physically hold cord in
The most likely problem is the power socket on the laptop, it may be just a dry solder joint and needs to be resoldered or it may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars. If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
Posted on Jun 12, 2009
SOURCE: phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
Posted on Apr 28, 2010
My phone will not turn on
You do not say which phone it is . If you can remove battery do so and then replace it. has it got a charge have you tried charging it
Mar 03, 2015 | Cell Phones
My iPhone fell down and wount charge
Did it fall while plugged in. If it fell and the cord was jerked it could possible have a dislodged wire in the IPhone cord plug. Try another cord
Oct 14, 2014 | Cell Phones
If the end of the charger broke off inside your nabi, it will be difficult, but you can get it out. Ideally you still have the broken piece. Superglue the end, put it back in and let it set, then pull it out quickly. If you don't have the rest of the broken piece, you can use something like a toothpick or a cotton swab with the cotton tip removed. Check out YouTube for videos on this. If your charging cord just fell apart and nothing is broken inside your nabi, just buy a universal charging cord. Make sure the tip matches the one you broke. Amazon is a good place for finding these. It will still charge your device.
Apr 16, 2014 | Nabi 2
Rca tablet wont charge
We are having the same problem with all 3 of our RCA tablets. Like you said, we have to find the right position for the charger and hold it that way. If you can hold it for a couple of minuets, the battery icon will flash and you will be able to tell if it's charging. Very frustrating I know. We will never buy RCA again. They are honestly junk.
Dec 27, 2013 | Televison & Video
Toshiba SAT A505-S6005 Power cord was plugged when laptop fell to the floor and hit where the cord attaches to the receptical (on computer) which jammed (pushed) the thin connector prong further into
When this happens it means that the whole recepticle has been broken off of the motherboard and the whole laptop will have to be disassembled. This is not an easy job for someone who hasn't done one before. After it's disassembled it has to be determined if the recepticle can be resoldered or not. Sometimes the damage is not repairable. Good luck!
Nov 22, 2012 | Toshiba Computers & Internet
My power connector on the phone came loose and now it won't charge.
That should be the charging port. You need to get it replaced.
Main while, you can use a desktop charger to charge the battery separately till you get you charging port fixed.
Dec 29, 2009 | Sony Ericsson W760i Cellular Phone
Wont charge
Sounds like a "hot" wire made contact with a "ground" wire...what you're smelling is the melted insulation as the wire(s) shorted out and over-heated. If protection circuitry within the phone kicked in, it's possible that it will do a self-reset after it cools off and everything will work fine. If not, you'll need to bring it in to an Apple authorized repair location for diagnosis and/or repair.
Aug 12, 2009 | Apple iPhone Smartphone
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
HP Pavilion xf125 PC Ntbk ac connection is broken won't charge
You need a new motherboard, ac connector are very hard to solder back on to motherboard and wouldnt advise anyone trying it.
Apr 11, 2009 | HP Pavilion xf125 (F3412HR) PC Notebook
W810i not charging
basicly there are 3 pins on the top of your phone (take the battry out and you shall see them on the far end) get a pair of tweezers and push the clips in and hold for a while ... slot your battrey back in and put it in charge it should work :)
Jun 28, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
