Question about LG Refrigerators
How to adjust the water level on my ice maker LG lmx25964t
  • 489 Answers
SOURCE: LG Ice maker
You may have a broken ice maker and it needs to be replaced. You will need to have a qualified LG technician assist you.
Posted on May 11, 2008
  • 8 Answers
SOURCE: fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
Posted on Feb 20, 2009
SOURCE: LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
Posted on Mar 22, 2009
  • 286 Answers
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
This happens when the teflon on the mold is peeling.(flaking) It pushes water over the side. Otherwise check the clip in the back that holds the fill tube in the water cup. If the clip is missing then the fill tube could be splashing water over the mold
Posted on Jun 26, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE ice maker, solid ice in ice maker
Many ice makers have an adjustment screw behind the front cover that shows plus or minus. Try the minus turn of the screw that should shorten the amount of time the ice maker fills. If electronic please call the company you purchased it from and explain the problem. Sea Breeze
Posted on Jul 24, 2009
How to adjust water fill level to icemaker on LG LMX refrigerator
If it is not on the ice maker unit itself, the machine does not have an adjustment. LG Ice Maker Assembly AEQ36756901
Jun 19, 2016 | LG Refrigerators
Hi have LG fridge, ice maker making ice but freezes into one solid block instead of staying in individual ice cubes making it impossible to dispense do you have any ideas a sto why this is happening and...
Sounds like this is a water level problem. Too much water is being released into ice tray, which raises the water level above the depth of each cube form, causing one big cube. You can adjust the water level.
Check this out:
How to Adjust the Water Level on an Ice Maker eHow
Jul 19, 2014 | LG LSC26905TT Side by Side Refrigerator
My ice freezes as a block when dispensed into ice tray
There are water level adjustment screws behind the plastic cover of the ice maker to adjust the water level when it refills after dumping a tray of ice. When there is to high of a water level it spills over onto the cubes freezing them into a big block. Try to adjust the level of water. There is a arrow which tells you which way to turn the screw to get a smaller fill fixing the problem.
May 04, 2014 | Refrigerators
I have an amana side by side model # JXD2252L. The ice maker is adding too much water at the beginning of the cycle and is dripping water into th ice bucket. It freezes and casues the ice dispenser to...
Adjusting Ice Maker Fill
Use a flat-head screwdriver to remove the screws on the ice maker's front access panel, and then remove the panel.
  • Locate the adjustment screw, located about mid-point on the side of the ice maker. Do not turn the crew more than one full turn in either direction.
  • Turn the screw clockwise ½ turn to decrease the water fill level.
  • Turn the screw counterclockwise ½ turn to increase the water fill level.
  • Close the access panel and restore the screws. Turn the refrigerator back on.
  • bobicehouse_20.jpg Look at mid point for adjusting screw
    Jul 10, 2011 | Amana ACD2232HR Side by Side Refrigerator
    HOW DO YOU REPLACE THE ICE MAKER IN A AMANA REFRIGERATOR MODEL NUMBER SZD25NL. I UNDERSTAND THE REPLACEMENT ICE MAKER PART NUMBER IS AP4135008 MADE BY WHIRLPOOL. IS THIS CORRECT? THE ICE MAKER THAT IS...
    You may not need an ice maker. See if it is level. If the ice maker is overflowing with water there is an adjusting screw to lower the water level.
    Jan 29, 2011 | Refrigerators
    How do I decrease the water level in my Maytag Ice Maker
    depends on the model of ice maker not your refer,,
    if you have a white box on the end see if you can pop it oiff
    if you have the adjustable model you will see a screw with a plus minus
    turn to adjust.... make sure you unplug the unit first
    1/4 turn is 1 oz
    Oct 24, 2009 | Maytag - Model IC11B
    Have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
    Unless someone has made a water level adjustment there is,
    Only one repair. Replace the ice maker.
    If someone has made a water level adjustment you can try this.
    Remove the ice maker plastic cover. Locate the water level screw adjust it to a minimum setting and try it there.
    If that does not correct the problem, replace the ice maker.
    May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
    Fridgidaire refridgerator - adjust water level in ice maker
    Jan 17, 2009 | Frigidaire FRS26R4A Side by Side...
    Ice maker water level too high
    generally, there is a screw adjustment for this. usually, turning it clockwise sends more water during fill period (makes period longer). try it and adjust clockwise or counter-clockwise as necessary. Now finding the screw...try prying (or unscrewing) off the plastic cover over what appears to be the ice-maker unit (may also be on back side of frig.
    Sep 16, 2007 | Samsung RS2534 Side by Side Refrigerator
    Refrigerators Logo
    61 people viewed this question
    Top LG Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
