Question about Maytag Dryers
Have to reset breaker for it to work
Turns off and have to reset breaker for it to start again, but
it does not loose power because the light stays on
  • Maytag Master
  • 3,361 Answers
You have a weak breaker. The light(120 volts) is working off the good side of the breaker. Replace the breaker in the circuit panel to solve your problem.
Posted on Jul 25, 2009
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
785pi
1) test the outlet wall, put some desk lamp, and see if turn ON the light, is does the circuit is o.k if NOT the circuite is missing , Reset The c.breaker from your house or replace the blown fuse.
2) if everything is o.k, turn ON the treadmill, if does work test the fuse blown y/o reset the c.breaker see the block diagram +diagram
3) test the main switch for loose wires, or bad contacts, or faulty swithc.
4) see any wires loose, maybe broken, or break, tight very well, see if some animal byte some wires connector. repair and TURN ON again.
5) adjust the REED switch, see the diagram clean it, tight the wires connector well.
Try again. God bless lyou
Jul 29, 2012 | NordicTrack Treadmill
My Cyberpower 550VA keeps turning off. I can turn it on, and it will stay on for maybe 2 seconds, and then it turns off again. Any solution?
your ups cannot get enough power from the outletreplace the battery of your ups 12volt 7ampere reset the small breaker. when it still turning off test the continuity of the small breaker and the cord to plug use a multitester.
Aug 25, 2011 | CyberPower 550VA 330W UPS Green S System
I triped my breaker that controlled the unit and reset breaker but of the 2 green lights the one on the left is blinking unit power on but doesnt stay on for but a few miniutes please advise the unit...
Please don't try again and again. The breaker tripping is an indication of fault in your a/c.
Check indoor and out door for loose contacts.If anything, rectify. Check blower motor, fan motor and compressor for grounding. Check with an ohms meter, keep one end with any tewrminal and second with ground. If anything reading even 00.00, it's grounding. The particular spare/s to be replaced. Call repairman to check, if you're not aware of it. Thanks.
Feb 08, 2011 | Heating & Cooling
Can a circuit breaker fail? There is no power in my daughters room, but the circuit breaker seems to be fine. It doesn't reset or fix the problem.
Make sure to click breaker completely over to one side and then click all the way back to reset.
Yes, breakers go bad.
You can check your breaker in a simple way.
Turn main breaker OFF.
Mark daughter's breaker.
Take cover off breaker box.
The main breaker will still have power on the lugs where big wires connect.
Rest of box will have no power.
Notice that each 120 volt breaker has a wire connected to end of breaker.
Use screwdriver and tighten this wire.
If screw is already tight, then loosen screw and pull wire out, and move wire to another breaker marked with same amperage. For example if daughter's breaker is 20, then move wire to another 20. Now there will be two wires connected to that breaker.
Turn power ON and see if daughter's room is restored.
This set up will work fine until you have time to replace breaker with same brand as marked on breaker box, usually available at home center (if available).
If power is not restored by moving wire, then there is a loose wire inside a junction box located in daughter's room.
Test each receptacle in room to confirm that nothing on that circuit has power.
If some receptacles have power, start opening other receptacle boxes looking for loose wire, especially at the quick-connects where wires stab into back of receptacle device.
If whole circuit is off, then to isolate location of loose wire, start at the ceiling box, and see if there is a loose black or white wire. Most electricians run wire from breaker to the ceiling box, and then other wires spread out from there and go box to box until each box has a black and white wire that connects back to original breaker.
Dec 29, 2010 | Electrical Supplies
Midea model MSB24CR After a while cuts off flashing lights on panel (auto-timer- operation) . Cant restart until reset breaker Thanks
TAKE THE UNIT OFF OF AUTO-TIMER AND TURN THE POWER OFF
AT THE BREAKER...UNPLUG THE UNIT IF APPLICABLE AND WAIT
3 TO 5 MIN...TURN BREAKER BACK ON AND PLUG IN UNIT IF
APPLICABLE AND RE-PROGRAM. YOU MAY WANT TO WAIT TO SEE IF IT RE-PROGRAMS AUTOMATICALLY... AND RESETS...IF
THIS DOESN'T WORK YOU MAY NEED A NEW BREAKER...CHECK FOR ANY LOOSE CONNECTIONS WHILE POWER IS OFF...
Mar 27, 2010 | Heating & Cooling
Breaker tripped, wouldn't reset. After about 20 minutes it reset.
YES YOU ARE IN DANGER. DO NOT turn this breaker on again. Please get a registered electrician. There is a risk of fire or even explosion. BE CAREFUL. Have you got a smoke alarm?
Feb 05, 2010 | RTO Circuit Breaker Box For Electrical...
I have a kscs25inss kitchenaid refrigerator. I opened the door and there was no power, the unit was not running (no compressor, no lights, no water). The circuit breaker did not trip, but I reset it...
Hi, Most likely the outlet has a loose wire or the cord for the refridgerator has a loose wire. Check the outlet on the wall see if it moves at all or has any loose wires in the back...if that looks ok replace the cord to the refridgerator. If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Sep 18, 2009 | Refrigerators
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Dryers Logo
43 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
