Question about The Computers & Internet
How can i disable the buttons on the side of the mouse
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Jan 31, 2016 | Toshiba Satellite C655D-S5120 Notebook
How do I unstick my curser. I have re-booted, shut off and restarted the computer. I can not get it to move at all but the curser will move if use external mouse
You should have two buttons either side of your power button,
one of which (the right hand side i believe) controls your wireless connection, and if pressed your notebook will not be able to pick any wireless connections up.
The left hand side button controls your touch-pad device, possibly you have pressed this button without realising and it has disabled your mouse. Simply hit it again to resume the function of the mouse.
Aug 01, 2011 | Acer Aspire One PC Notebook
My niece was playing on my computer. My mouse doesn't work now. Is there a button on the keyboard that turns the mouse off? The touch mouse still works.
There is no button to turn off or to disable the mouse function.. But you can set or disable your mouse by configuring to your Device Manager. But take not, before you disable your mouse, you should know how to use shortcut keys and use only keyboard to navigate your files..
May 27, 2011 | HP P2360AA Keyboard/Mouse
Is there a way to disable jus the side scroll bar on my gateway laptop touchpad without disabling the mouse itself? on my touchpad if my hand jus gets in front of the touchpad it scrolls and makes my...
yes. its in the control panel under mouse properties. Look for the advanced properties, theres alot of settings you can change there for the touch pad. There might be a link to the program in the start menu too.
May 15, 2011 | Gateway Keyboard/Mouse
Orange light comes on occassionally on mouse pad and cursor freezes, how do i stop this
Tap the orange light quickly two times to enable the touchpad. Touch the same spot twice to disable the touchpad. To see the instructions from HP type "mouse" into the Search Programs and Files. Click on "Change mouse settings" and click Device Settings. Click on "Settings" and click "Touch pad disable zone". I was delighted to have found this as I had been restarting the computer manually to enable the touchpad. Shame on HP. The instructions for this simple problem are difficult to locate for the average user. They can do better.
Dec 08, 2010 | HP Compaq Presario F730US Notebook
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Toshiba touchpad scrolling
Go to the Classic view of Control Panel...click on Mouse...click on Device Settings...click on the Settings button..it will bring up a new window about Synaptics....click on Virtual Scrolling. Un-click the horizontal and vertical scrolling button and click Apply down at the bottom and it is disabled. YAY!
Sep 02, 2009 | BenQ Joybook 5100U Notebook
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Can't get magnifier off screen
First of all make sure to update to the latest driver. The problem is, the side buttons are very easy to push without meaning to do so. Right click the mouse icon in your system tray and select "Mouse Properties" select the BUTTONS tab, then disable both the left and right side mouse buttons. Click on APPLY and then OK
Jan 18, 2009 | Microsoft Wireless Laser Mouse 5000
Mouse
Normal 0 Go to Control Panel and click on the Mouse icon.
Then select the mouse button you need to program.
Hope this helps. Bud
Sep 25, 2008 | Logitech Cordless Mouse
Computers & Internet Logo
37 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
