My tv is now an audio tv i search Chanel but it remains on thesame position donot what do to
How do i finde auto chanel seargh
Auto channel search is how your tv finds channels that are available. Under settings in the menu should be initial set up. There you will find channel search.
Feb 20, 2015 | Insignia Televison & Video
My sharp aquos tv power light is blinking but it donot power on.try to reset by presing and holding down the volume and chanel.but dint work,
Could be the powerboard, try unplugging in and leave it off and unplugged overnight and try it again. If this doesn't work see and tv repair tech.
Jan 26, 2015 | Sharp Aquos Televison & Video
Emerson tv 32 in --the channel 7.1 ABC only has picture without sound.
Check the Chanel 7 broadcast signal on the other tv have sound,could caused by the tv broadcasting signal from the tv station itself.Check if ur tv have a function known as S.A.P. make sure it is off,could effected no tv audio problems,because the tv station in ur city or town don't broadcast in that signal frequencies.
Feb 24, 2013 | Emerson Televison & Video
When i search radio chanel with SCAN UP of DRA-275rd radio, he stop on a near frequency but not exact frequency, so i cant to tune in a station. could you help me please?
Check on the back of the unit for a switch marked "channel step" or something similar.Usually close to the anntena socket or connection.When you find it switch it to the alternative position.This should solve your problem.
Jun 18, 2011 | Denon DRA-275R
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
Vizio tv chanel search is not finding digital chanels.
On your remote, select input as TV, then verfiy that you have set to Antenna, Then scan for channels.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Vcr record a show
If you tuned desired chanel in VCR Tuning system, you can record it while TV remains Off.
Aug 01, 2008 | Televison & Video
Soney 32" flat screen tv. 2006
Try going into the television, and changing the audio setting to stereo, it sounds like it set to SAP (second audio program).
Feb 10, 2008 | Televison & Video
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
