What happens if u use two jars with hot and cold water
How to avoid condensation on the inside cover of homemade jams?
That is natural water vapour. You may find cooking for longer will remove the water and stop it happening. Don't forget, air with water allows bacteria to grow. Only if there is both of course!
Oct 27, 2014 | Sur La Table Le Parfait Homemade Jam Jar,...
Hot water continues to run from washer does not stop have to turn off hot water supply. Samsung front load one of the first models made
solenoid valve for hot water may be stuck or faulty. If you have a cold water supply, you may be able to run the machine using only cold water, turn off the hot water and keave cold on, see what happens.
Jan 08, 2013 | Washing Machines
I have a samsung sw52asp top loader fills but wont switch off water and go into wash cycle it just
  1. It sounds like your Water Inlet Control Valve may be getting stuck, or is stuck. There are 2 water inlet control valves, 1 for hot water and 1 for cold water. Does this problem happen when using the hot water only, or cold water only? You will need to replace the water inlet control valve for the side that is stuck open.
  2. If this problem happens with hot water and cold water, you may have a faulty control board, which will need to be replaced.
Mar 01, 2011 | Washing Machines
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
I just installed a Moen shower valve Model 82910cbn. The cold water supply is on. The shower works when the cold and hot water is going to the valve, but when I turn off the cold water supply going into...
This is taken from the Moen manual. You can download it here:
Balance Spool Maintenance
The precise and instantaneous pressure control illustrated has been
achieved through the balancing spool, which has been manufactured to
exacting tolerances.
During construction or valve installation, foreign material such as solder
flux, pipe cuttings sand, dirt or wood is unavoidably introduced into the
water system. Occasionally, however, rare, these foreign materials can
cause the balancing spool to become stuck temporarily between the
rough-in and trim-out operations. If this happens, it will be apparent at
the trim-out test, in that the valve will deliver only a small trickle of water
or it will deliver only hot or cold water. If this occurs, proceed as follows:
1. Make sure that both the hot and cold water service lines are ON. Also,
make sure that both screwdriver stop-check valves are open. The valve
WILL NOT OPERATE unless both supplies are ON.
2. If the valve still does not function properly, turn off both the hot and
cold supplies and remove the balancing spool, using a wide blade
screwdriver. The inner piston of the balancing spool should shake
back and forth freely. If this is not the case, jar the spool on either
end to remove the foreign material and free the spool. When the
spool is free, replace it; turn ON both water supplies and the valve
will function properly. If you are unable to free the inner piston,
replace the entire spool.
Oct 16, 2010 | Moen 3175 Legend One Handle Shower Faucet...
The washer is set on cold/cold. The hot water faucet is turned off. The washer should not be asking for hot water because it is set to cold/cold. It asks for and received cold water. At some point...
Newer machines know the water temperature. It will mix hot water even on a cold setting if the incoming water is too cold. Detergents need a temperature of at least 60 to activate.This will only happen in the winter usually.
Feb 24, 2010 | Washing Machines
Heater blowing cold,new matrix,thermostat,control valve ok,hot water going thro matrix but still blowin cold fiesta 1.8de 2000 any help pls am bldy frozen
control flaps on heater unit ,have a play and as a temporary job jam the right flap open with piece of wood *** packet ,anything ,but get some heat into jam jar its dangerous driving with no demister and cold feet and fingers ,hate the cold ,its so painful
Jan 09, 2010 | 2003 Ford Focus
Hot water first from faucet, two minutes later cold???
you could be having a problem elsewhere in house system! do you have a garden hose hooked up with a "Y" hose? or something in system were hot and cold connect...then a valve after? what happens is the hot water can back siphon through cold lines..its rare, but this happens, and is dangerous! water from hot water tank is full of bacteria, and if you drink it , well thats not good!
Mar 26, 2009 | Chicago Faucets CHICAGO FAUCET Mixing...
Cold water not running.
check the cold water selenoid on the water valve
May 05, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
