Did an update as requested and now have a screen with a picture off side . There is a k in a yeellow square and a blue backgriund lower part of the screen has vertical lines. Wording is LC - 32
  • 375 Answers
SOURCE: No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Posted on Aug 18, 2007
  • 579 Answers
SOURCE: 40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Posted on Jan 06, 2008
  • 6 Answers
SOURCE: THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Posted on Feb 15, 2008
  • 53 Answers
SOURCE: Vertical line
Sorry, you have a defective LCD panel. If your TV is still under warranty, contact Sharp to get the TV exchanged. Otherwise, LCD panels cost more than the TV is worth.
Posted on Mar 26, 2008
freetek
  • 5568 Answers
SOURCE: green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Posted on Jul 09, 2008
Registry problem
You must have an authorised (legal copy) of windows xp.
Registering Windows XP enables Microsoft to notify you of essential program updates, security issues and available program patches.
Although registration is optional, you are required to first validate and activate your software to ensure that it is not a pirated copy.
Windows XP has a built-in function that will lock a non-activated genuine Microsoft product after it has run for 30 days
From the Start menu, click "All Programs," then "Activate Windows."
A blue window will appear with a picture depicting a set of keys in the top-left corner, and a message saying "Let's Activate Windows."
Click the topmost radio button marked "Yes, let's activate Windows now."
Click the white "Next" button on the lower-right corner of the window and follow the instructions to activate your copy of Windows XP.
The final blue window of the activation process will be marked "Register With Microsoft?" Click the white "Yes" button at the lower-right corner.
A new pop-up window marked "Collecting Registration Data" will appear.
Fill in the form by typing your personal details into the sections provided.
At the foot of the form you will find two blank white squares followed by messages asking whether you wish to receive special offers and promotional material from Microsoft.
Click on one or both of the white squares if you wish to participate; if not, leave them blank. Click the white "Next" button in the lower right corner of your screen.
A "Thank You" message will appear. Click the white "OK" button in the lower-right corner to complete the Windows XP registration process.
Hope this helps.
Nov 24, 2012 | E-Machines W3050 PC Desktop
BLUE RAY ONLY SHOWS IN SMALL SQUARE. THE PICTURE ONLY SHOWS IN THE MIDDLE OF THE SCREEN IN A SMALL BOX. NO MATTER WHAT IS TRIED THE PICTURE SIZE WILL NOT INCREASE. THE PLAYER KEEPS READING LOADING. I'VE...
This problem is easily fixed! I also have a BDP-S350, and had the same issue on "Crank 2-High Voltage". The fix is to put a USB memory stick into the port at the back of the player, 1GB is plenty big enough. This film and others play fine on PS3's or anything that has internal memory, but the 350 needs a memory stick permanently fitted. Also, make sure you have the latest firmware update on your player. Happy viewing!
Oct 10, 2010 | Sony BDP-S350 Blu-Ray Player
SONY PROJECTION TV TROUBLE SHOOTING BLUE SCREEN
This was one of several Sony models that had bad picture tubes--the set uses a red, green, and blue tube.
There is something easy you can try that may help you get some more life from the set.
SONY SCREEN ADJUSTMENT:
Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the GREEN will be in the middle.
7.) Once you locate the BLUE screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the Blue screen down until the set stays on and then very slowly turn it up until you see a slightly Blue screen with or without diagonal trace lines----turn it down slowly until the Blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the screen down a few times to get it to stay on.
If it works you may only be buying some time--if the blue tube caused this it may return at some point.
If all this information has helped you rate this solution as I do this here for free.
Regards, SD TECH
Dec 20, 2009 | Sony KP-51HW40 51" Rear Projection...
Full Color fading to blue then screen turns off. Repairable?
6.)Usually the blue will be on the bottom left--it does vary
7.) Once you locate the BLUE screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Blue Screen control.
8.) Best way to do this if the set is on is on a video input with nothing connected--you turn the blue down until the set stays on and then very slowly turn it up until you see a slightly blue screen with or without diagonal trace lines----if you get it to turn on this way turn the blue screen back down slowly until the blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the blue screen down a few times to get it to stay on.
I do this here for free and if this helps you at all give me a vote here--it costs you nothing.
Regards, SD TECH
Sep 17, 2009 | Sony KP-65WS500 65" Rear Projection...
Can't turn off the "searching" icon (on just the blue screen)
there may be a setting in the menu for auto-search to be turned on or off.
Sep 16, 2009 | BenQ PB6100 Multimedia Projector
Certain pictures and vidoes dont open or play
Hello fgskas,
This is due to not having the correct plugin on the computer to view these pictures and videos. You may want to try downloading flash and java updates. You can get flash from www.adobe.com and you can get java from www.java.com.
Mar 30, 2009 | Dell Dimension 4700 PC Desktop
A BLUE SQUARE ON BOTTOM RIGHT SCREEN, 42 IN OLEVIA LCD. CANNOT REMOVE IT? THANKS
The blue square you are seeing is from PIP, (Picture In Picture). I got it the other day & found how to turn off PIP.
Feb 22, 2009 | Vizio L32 32 in. LCD HDTV
TV Screen not functioning correct
Sounds more like a malfunction. Most likely the lcd panel or digital board. If lucky possible a bad solder connection but unlikely.
Jun 05, 2008 | RCA L26W11 26 in. HD-Ready LCD Television
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
