Question about Sony Televison & Video
How do I select HDMI. I can select Video 1-7 but I don't see an option for HDMI. I don't Have the tv remote just a Direct TV programed for the Sony Bravia. Thank You!
wyoed1
  • 211 Answers
SOURCE: cant program directtv remote to sony tv
See if this web sight helps in your problem
Good Luck and have a great day.
RCA Universal Remote Control-Programming Codes
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 26, 2008
SOURCE: hdmi
Bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "S H Pos Reg B". It should be "10", change it to "11".
Press the menu bottom to drop out of the menus, and the standby button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
Posted on Mar 30, 2009
SOURCE: Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
Posted on Nov 28, 2009
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Posted on Mar 21, 2010
dbTVfixer
  • 79 Answers
SOURCE: cant get the remote to
To diagnose a remote control problem follow these steps.
1) unplug the TV power cord, count to five and plug it back in. (reboot)
2) try to power on with ORIGINAL MANUFACTURER remote.
if that works- your TV and original remote are fine.
if that does not work:
4) try to power on with buttons on the TV itself- if it works- check your remote batteries and try remote again.
Direct TV and Dish Network remotes will ONLY operate SIMPLE function of your TV such as power, volume, input.
They will NOT access your TV menu.
Posted on Apr 12, 2011
How do I set my Vizio tv up so it will let me watch movies on a Sony DVDs player
Assuming the DVD player has an HDMI port, run an HDMI cable from the DVD player to an available HDMI port on the TV. Let's say you have your TV service going to HDMI #1 on the TV, you can run the DVD to HDMI #2. When you want to watch a DVD, you must select the input/source on the TV remote to change it to HDMI 2(or whichever port you used). When ready to watch TV again, use the same button to change back to HDMI 1 (or whichever HDMI port you used for TV service). If you do not have an HDMI port on the DVD player, then you must use whatever type of connection it has and connect to the corresponding port(s) on your tv, Then follow same directions as above regarding choosing the input/source on the TV remote.
Dec 02, 2017 | Sony Televison & Video
I have audio but no picture, just "Video 1"
You didn't mention tv make / model so thjis is only a guess . The tv may need tuning to find the direct tv cable.
Jan 07, 2015 | Audio Players & Recorders
Sony Wega KV-30HS420 input problem
Just reset the TV to its factory settings and check. To do this you have to enter its service mode option. How to enter the service mode option is described in one among the posts at the site linked here.
But, before doing this reset, just connect the HDMI cable to the TV, and input an HDMI signal to it. If there is no input signal, the set will display as 'no input'. Check this first. If you wish to get further assistance from me, come over by FiXya comment.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 17, 2014 | Sony FD Trinitron WEGA KV-30HS420 30" TV
How to activate my laptop to my samsung tv
If you mean watch what you see on your laptop on your TV, then you need to connect an HDMI cable or S-Video cable (depending on what sort of ports you have) from your laptop to your TV, then select the appropriate input on your TV or TV remote. For example if connected via HDMI and your TV has 2 HDMI inputs (ie. HDMI 1 and HDMI 2), select which one you connected to.
Jan 26, 2012 | Sony VAIO Notebook
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
Can not find codes for toshiba remote for my sony dvd home theater changer nor any specifics on hooking it up properly and it has s video but no hdmi hook ups help By the way i already pd 1459.00 dollars...
To find the code for the Toshiba remote to the Sony DVD changer.
If you do not know the device code for a particular device, you can view each available code for that device mode and sample the functions to find the code that operates the target device. 1 Press a mode select button on the remote. 2 While holding down INFO button , press 8, 5, 0, 0. The remote control enters program mode. 3 Point the remote at the target device and press Power button, 1, VOL UP, CH UP or PLAY. Some keys are ignored if they are not applicable to a specific device mode. 4 If the device responds to the remote control: Press INFO button to store the device code. The mode select button blinks twice. The remote exits program mode. 5 If the device does not respond to the remote control: Press UP. Press POWER. Repeat this step until the device responds to the remote. Press INFO . Note: When a search cycle is completed, the mode select button blinks 3 times. The remote displays each available code again. If no key is pressed within 10 seconds, the remote exits program mode and returns to the previous code.
The previous section was from the manual p.86: http://www.iusermanual.com/tv/toshiba-46vx700u-tv-manual.htm
Hooking the DVD changer to the TV: The TV has composite video inputs and can accept s-video by a adapter cable as in: http://www.amazon.com/S-Video-3-RCA-Composite-Cable-Laptop/dp/B002ZKTCUM/ref=pd_cp_e_1
May 05, 2011 | Toshiba 46VX700U LCD TV
No video/display on TV when using sony str dh 500
If your set up is HDR-AVR and TV all you need to do is go HDMI out from HDR to HDMI in(Sat.) of AVR and monitor out HDMI (or composite video) to TV. and select the Sat. input on the AVR. The sound is only comming from the HDR in this case and the composite video or HD video is being switched out to the TV when you select Sat. on your AVR
Sep 20, 2009 | Sony STR-DH500 A/V Receiver
Connected to direc tv box with no sound or pic
The PS3 is connected to your TV via one of the inputs on the backside of the set? If so, the input you used can be selected from the remote or from your menu buttons on the physical TV. The remote will have a button labeled video(video inputs) and by depressing it you can scroll through different selections ie... Svideo, TV, colorstream 1 & 2, HDMI(which is probbaly the best, but you will need an HDMI cable)
Apr 08, 2009 | Sony Playstation 3 (PS3) Console
Connection problem with Denon 589 and direct tv
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 08, 2009 | Denon AVR588 Receiver
No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Jan 06, 2008 | Onkyo TX-SR875 Receiver
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
