I want to log into my open enrollment. - Computers & Internet
I have not received my ID card from Express Scripts, even though I got my enrollment letter on 11/1/2017. When can I expect it?
Maybe deliveries from express scripts are facing some delays issues because of holidays. Give the. 2 to 3 working days to deliver your enrollment letter
Jan 01, 2018 | Express Computers & Internet
I want to login to blackboard
I believe you have to be enrolled in the school or a member of the faculty to log into the "Blackboard" of that school.
Nov 03, 2016 | Computers & Internet
How can I access with my aeroplan points collected
Go to website:
http://www4.aeroplan.com/log_in.do?SiteArea=myaeroplan&title=ae.transactions.title
and sign-in or enroll. Once logged-on, the site will tell you how many points you have collected and what you can do with them.
Jan 09, 2015 | Cell Phones
I wish to close out my enrollment with facebook
Head to https://www.facebook.com/help/delete_account . ->Log in->Hit delete account. Your account will be deleted after 12 days. Remember to not login in during the 12 days, if you do so the counter resets.
Hope this helps. :)
Aug 06, 2013 | Computers & Internet
Fingerprint reader working but not showing image
From the description it is a software problem, If you were sticking things in the scanner bar that would not help and it will prevent the laptop from working.
Mar 30, 2012 | HP Compaq 6910p Notebook PC PC Notebook
My veriFace Recognition program on my Lenovo opens and enrolls my face. Once I do that I logged out but it didn't show up. I think it gets set up through the 'Log' tab in the program, but it...
Welcome to FixYa!
There's a possibility that the software itself is corrupted, you will need to uninstall and reinstall the software. Follow the instructions below for you to be able to fix the problem.
1. Go to the Control Panel and uninstall Lenovo Veriface.
2. Restart computer.
3. Go to consumersupport.lenovo.com
4. Choose the model and Operating System of your laptop or you can just type the serial no of the laptop.
5. Look for Lenovo Veriface software on the list and install it.
Hope this information will help. Thank you for using FixYa!
Jun 04, 2011 | Computers & Internet
I need to reset my bios password.i have forgotten the password.but i have the fingerprint that enrolled.but i have unchecked logging on with fingerprint.my laptop is A8-S8314.thank you
To reset the BIOS read the information from this link: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
In case of your laptop the easiest method would be using Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 20, 2010 | Toshiba Tecra A8-S8314 Notebook
How to setup finger print sensor
When you start a machine with a Fingerprint reader for the first time, you will see the following screen when you reach the Desktop. This is the main console for configuring and managing the Fingerprint reader.
Here you can enroll your fingerprint, and adjust your Power-on security settings.
When you click on “Create new passport and enroll fingerprints” you will be prompted for your logon password.
Once you enter your password you will see the main enrollment screen.
You can select a fingerprint to enroll either by selecting the fingertip with your mouse, or by choosing from the drop down list. To enroll, either double-click the fingertip you wish to use, or press the Enroll button
On the left is an animated finger that demonstrates how to swipe. You must swipe your finger three times to enroll.
If your finger is not centered, you will be prompted to move it to the right or to the left. If it’s not able to read at all you will be prompted to try again.
When you swipe successfully, you will see the highlighted portion go to No. 2 for the finger printer to be swiped again.
Once you have swiped three times successfully, the three images merge into one and you are brought back to the main enrollment screen, where the enrolled finger is shown with a red dot.
  • You can enroll multiple fingers.
  • The Enroll button has changed to say Delete. This allows you to delete a fingerprint you have already enrolled. If you used the mouse to click on a fingertip that was not already enrolled, the button would change back to Enroll.
When you click Next you are brought to the Power-on Security screen.
This is also the second choice from the main Fingerprints enrollment screen. Here you can use a fingerprint to replace your Power-on passwords if you are using them.
If you are using Power-on passwords, then select the box at the top. When you click on the Add button, you will be shown a list of the fingers that you have enrolled, and can select which one(s) you want to enable to replace your Power-on passwords.
Once you select a choice from the box, the finger will show up in the list. The first time you restart your machine after this, you may be asked to swipe your fingerprint as well as enter any Power-on passwords you have set. After that you should only be asked for your fingerprint.
  • Predesktop Authentication
    • In addition to the process above, there is a setting in BIOS that must be enabled for a user to be prompted for their fingerprint instead of a Power-on password. The Default for this Setting is “Enabled”, so no change should be necessary. It is in the Security Section under Fingerprint. The setting is called “Predesktop Authentication” Again, the default is “Enabled”. If disabled, a user will not be able to use their fingerprint on Power-on.
  • Security Mode
    • This controls what password will allow a user access to the system if they are not able to gain access using their fingerprint. The default setting is “Normal”. This will allow the use of either a user Power on password, or a Supervisor password instead of a fingerprint.
      The alternative setting is High. This will allow only a Supervisor password to be entered instead of a fingerprint to gain access to the system.
Once you click Finish, you will be brought back to the main Fingerprints screen.
The Create new Passport and enroll fingerprints choice has gone. Replacing it are two new choices:
  • Edit passport and fingerprints
  • Delete passport and fingerprints.
If you choose Edit passport and fingerprints you will be prompted to swipe your finger to confirm your identity
You will then see the password screen. Click next to go to the main enrollment screen.
This is the same screen that appears when you have successfully enrolled a fingerprint.
Here again you can delete or enroll fingerprints
I trust this was helpful and thank you for contacting the experts.
Jan 18, 2010 | Lenovo ThinkPad X300 Notebook
Moodle cookies
What OS are you running?
Apr 28, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
