Question about Oliso Irons
My Oliso Touch & Glide quit working. Now what do I do? I hacve always used distilled water.
2 Suggested Answers
  • 267 Answers
SOURCE: I want use distilled water in my new Rowenta DG8030 steam station but instructions say to use 1/2 tap water and 1/2 distilled water or 100% spring water. Why can't I use 100% distilled water? Why can'
Believe it or not, distilled water is quite corrosive, more so when hot. Distilled water doesn't contain any dissolved ions but the water is ionic in nature, the ions of every water molecule tend to dissolve away other elements. Steam generating plants and steam ships as well as steam heating systems treat the water with chemicals to keep the water from eating away the metals of the system and test the chemical makeup several times a day while operating. [I spent 4 years in the Navy on a steam powered ship.]
The same holds true for smaller steam appliances like espresso machines and steamers. A very thin coating of calcium carbonate [limestone] is a good protector but too much makes for inefficiencies and burned up elements.
Somewhere I read that Chrystal Geyser spring water is approximately the correct ion balance for espresso machines and I have been using it for years in my espresso machine. In any case you still need to occasionally de-scale your steamer per the manufacturers recommendations.
Posted on Feb 03, 2015
I got this iron for christmas, it shot steam 2 times and thats all. I had it set on cotton, linen. I used reg bottled water, should i use tap and why no shots of steam.
take it back for a warranty exchange after you check that the thermostat setting is on steam
distilled water is recommended for irons
bottled water ( filtered water) and tap water is the same product and will have minerals and contaminates that affect irons
Jan 02, 2016 | Oliso TG-1100 Continuous & Burst of Steam...
I want use distilled water in my new Rowenta DG8030 steam station but instructions say to use 1/2 tap water and 1/2 distilled water or 100% spring water. Why can't I use 100% distilled water? Why can't I...
Feb 03, 2015 | Rowenta Irons
Must I use distilled water?
Yes, it is ALWAYS best to use distilled water in any iron, no matter what a specific manufacturer may, or may not, say. The reason is simple: There's nothing in distilled water to contaminate your iron, and as a result, you will not have stained clothes.
If your iron is already dirty from using tap water... clean with mixture of vinegar and water by pouring mixture into iron, bring to full temp for a few mins, flush through steam vents, and rinse with distilled water. You may need to invert your iron to purge the water from tank as well. Repeat as many times as needed until perfectly clean.
Once clean, NEVER use any other type of water in you iron. Period. Always use distilled water. Hope this helps...
Jun 10, 2013 | Rowenta Perfect Iron
How to flush brown fluid from Sunbeam Steam Master steam jets and increase steam shooting?
There is commercial iron cleaner, but you can use white vinegar and distilled water to flush it. I would use a mixture of half and half. Then let it steam its little self, when it is clear, rinse with the distilled water again, This kind of thing happens when you use tap water and let it sit in it without rinsing after using. I always use distilled water and empty right away after use. Good luck
Nov 02, 2010 | Sunbeam 4214 Iron
What kind of water should be used in a Rowenta Titan Plus
It is always recommended to use distilled water for steam iron in general.
Second best is clean rain water.
For an expensive iron, I would not use Tap water as it has too many residue/mineral that will eventually cause brown/dark stains spots to be ejected from the steam iron pores!
You can buy 'bulk' distilled water for ironing from most supermarket and departmental stores. You can also use pure distilled water for car battery topping but auto shop tend to charge a premium for it!
Hope the information is helpful!
Hope the information is useful.
Sep 24, 2010 | Rowenta Professional DX8800 Iron
My iron smells bad and transfers the smell to clothing. I have had my iron for 10 years and love it, but my housekeeper left water in it.
Hey, You have a "Mildew" issue. Just like leaving clothes in the washer too long before putting them into the dryer. If you read your iron's manual, it is recommended to use "Distilled" water...not tap water. Tap water has impurities...Distilled water does not. Here's the fix...MAKE SURE YOU ARE HOME WHEN YOU DO THIS! Get distilled water (From Grocery Store) Mix 1/2 cup distilled water with 1/2 cup vinegar. Put this into your iron and leave it on. To help it along, push the "Steam" button frequently. You can do this several times...the acid in the vinegar will clean out the residue. Once this is done, fill the iron with water, add a couple of drops of lemon juice and you'll be good to go. I know this to be fact...just did it myself : )
Jun 16, 2010 | Rowenta DE851 Iron
Simac Stirelli 9000 steam iron spews rusty steam and smells like burnt apples
Your steam iron has been filled with 'tap' water that may have been contaminated (thus the smell). Rust develops more rapidely in Steam Iron chambers when distilled water is not used: to clean the 'enclosure' of the steam iron from rust and smell, over a sink or outdoor, fill 'cold iron' with a 50/50 water/vinegar and a teaspoon of bicarb, let it stand for about 10 mins, then turn the iron on and let it steam the mixture out while shaking the iron gently (DO NOT BURN YOURSELF! STEAM IS HOTER THAN BOILED WATER!). Refill and Steam flush again with Clean water (distilled preferred). Repeat the steps until the rust has been completely dissolved (check by steam ironing on clean pieces of disposible kitchen paper towel. Use the Power steam or Flush function of the Iron if available. Hope it helps!
Dec 17, 2009 | Irons
Instruction leaflet for Morphy Richards Iron 40659
It is always better to use distilled water, but this is not essential. However when using normal water, if the water has high salt content, white residue may be left on the bottom plate.
Jul 31, 2009 | Irons
Irons Logo
87 people viewed this question
Top Oliso Irons Experts
Andrew Taylor
Andrew Taylor
ray gallant
Bill Boyd
Are you an Oliso Iron Expert? Answer questions, earn points and help others
