Question about Toshiba Office Equipment & Supplies
I have Toshiba e studio 2507 feeder paper jam probable what I do plz help me sir
  • Toshiba Master
  • 653 Answers
Check the feeder feed roller, easily worn out
Posted on Sep 10, 2017
SOURCE: Jam in the document feeder
I think I found my answer. You don't have to un do any screws. Lift up the cover to the automatic feeder. You will see a spring on the side of the mechanism towards the front; remove the spring; that will allow you to lift up the little arm the spring was attached to and remove the roller or bar and the light blue/green plate just under it. Then you will be able to see the jammed paper, which which I was able to carefully pull out with a pair of tweezers. Some was under rubber rollers, but when I pulled the paper sideways it slipped out. Now it works!
Posted on Mar 09, 2008
  • 49 Answers
SOURCE: MP390 paper jam at feeder
First thing that comes to mind is that SOMETHING you (or someone) fed in, had a paper clip, staple, crinkle or some other unnatural thickness on one side of the paper - and it's stuck inside the feed mechanism.
I had the same exact thing with the feeder on my shredder. You have to get right inside you printer to find the problem.
Watever it may have been probably got stuck in the paper path so EVERYTHING from that point on gets skewed as it gets sucked into the printer and jams.
Can you get "IN" to clear the path?
Posted on Mar 30, 2008
SOURCE: Document Feeder jams
I got adventurous and removed the screws holding the document feeder. I then used a can of air and blew into the gears and then reassembled the feeder. It works perfectly.
Posted on Feb 06, 2009
SOURCE: paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Posted on Feb 20, 2009
mary_sparkes
  • 25 Answers
SOURCE: Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
250 prjm is caused by it not picking paper from mp feeder bottom door of two doors try loading paper on bottom door and pressing go should pick paper up looks like what the tray is not set to a4 check its on a4 on display this is a common problem as mp feeder is set to a4 so if it does not see tray 1 as a4 will go th mp feeder and as no paper will give 250 prjm
Posted on Oct 29, 2011
Toshiba studio 281c paper jam beeping volume
I suggest You Go to Official Toshiba Printer Page For You Toshiba Printer Problem On Below Toshiba forum URL Link: TOSHIBA TEC 452
Feb 27, 2014 | Office Equipment & Supplies
Document feeder error message
did u guys ever use maginzes to scan documents with they will get jamed in there i would open it up cheak feeders closly ok thx nick
Feb 09, 2008 | Office Equipment & Supplies
How to reset error code c21 in the Toshiba e studio 166?
how can to reset error code c21 my toshiba e-studio 166 printer
Feb 28, 2011 | Toshiba e-STUDIO166 Printer
I'm have error code e12 in toshiba estudio 350,pls help me!
hi there is paper jam in paper path plz first cheq yours machine for paper jam
thanks
May 12, 2010 | Toshiba e-Studio 350 Copier
A GRINDING NOISE IS COMING FROM THE COPIER AFTER A PAPER JAM
Hello sir;Check wherever the paper jam may still have some paper chip stuck inside cleaning up should be ok.
Aug 29, 2009 | Toshiba E-Studio 3511 Color Copier
Feeding paper for scanning/faxing - e-studio350
If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
Mar 19, 2009 | Toshiba e-Studio 350 Copier
E-studio copier won't multi feed, it jams
Hello sir; Open the feeder cover clean all the rollers by rubbing alcohol or rubber rejuvenator( recomend) it should take care the problem.
Feb 03, 2009 | Toshiba Estudio 200L Copier
Misfed document feeder
just check properly all document feeder may bi there is a piece of paper in feeder if not just check all sensors and levers .may bi some sensor is dirty clean all sensors in paper path and check all sensor levers .may bi some lever is jammed.mian jee
Jan 20, 2009 | Toshiba e-Studio 205 Copier
CALL FOR SERVICE estudio350
You can by-pass by putting the paper on hte glass and making the copies.
there is most likely a pice of paper or paper clip in the feeder
Oct 03, 2008 | Toshiba e-Studio 350 Copier
Toshiba Studio 200 CP
Use the manual paper feeder, and set the paper type labels
Jun 18, 2008 | Toshiba e-Studio 200 All-In-One Laser...
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
