Question about Baby Gear
I need a safety guard rail black metal ladder side square tubing for loft bed
SOURCE: Converting Simmons Crib 'n' More to a full size bed
You can call Simmons Customer support at 1-800-218-2741 and order the rails - they are $79.99 which includes shipping. I just did so yesterday. I had the same problem. I purchased this crib 5 years ago and now need the bed rails to convert to a full bed. You cal also email them at customerservice@sjfdec.com. Shipping takes about 2-3 weeks.
Posted on Jan 16, 2008
SOURCE: Toddler Bed Side rail for Delta Luv 5-in-1 crib
Try calling the customer service number (212)-645-9033. I have not called them yet to get the conversion rails for our Delta Luv 5 in 1, but I'm hoping that they will know more than Babies R Us!!
Posted on Sep 29, 2008
SOURCE: barrel nuts busted for toddler bed side-rail.
JUST BOUGHT 1 PACK OF 4 BARREL NUTS FOR STORKCRAFT CRIB AT CANADIAN TIRE FOR $3.59. WORKS GREAT!
Posted on May 01, 2009
SOURCE: I need bed rails for the simplicity ellis crib.
i have the same problem but i searched long and hard and found this wesite where you can purchase the conversion rails.
Simplicity Ellis Crib Conversion kit for Full size Bed
http://www.nybabystore.com/p-4994-simplicity-ellis-convertible-kit.aspx
Posted on May 06, 2009
SOURCE: one side of the cosco baby bed rail won't stay up,
I also have a Cosco baby bed. The side rail will not stay up, latch missing and needed parts.
Call Cosco Inc. 1-800-544-1108. I called Cosco and they asked me for the baby bed model # and date it was made. My baby bed was made 09/94. The model # and date are located under the bed.
They had the parts and are shipping them to me. I will have my bag of new parts in 7 days.
COSCO was so helpful.
Posted on Jun 16, 2009
Directions for assembling an IKEA loft bed - can't fins the name, but the ID n0 is 13672
if you can identify yours
this is there loft bed range
contact nearest ikea they can get you a copy of instructions
Loft Beds Frames IKEA
Loft beds bunk beds
Oct 24, 2016 | Furniture
Assembly instructions for pawsitively yours twin loft bed
I have a pawstivity twin over twin loft with rails build a bear works shop I need instructions on how to put this thing together and I also need some parts as well can any one help out with instructions or where I can print them at ??? Thanks
Feb 01, 2013 | Pulaski Pawsitively Yours Twin Loft Bed
What types of bunk beds are available?
The types of bunk beds include standard bunk bed,twin over full bunk bed, l-shaped bunk bed, loft bed, and a triple loft bed.For more information, check out this website: http://en.wikipedia.org/wiki/Bunk_bed.
Jul 30, 2012 | Furniture
Saw cuts bevel at 0 degree setting. Needs to set to about 3 degrees for square cut. Multiple saws with this problem. Is something bent, or worn out?
Check that the bed of the saw (the flat metal part on the bottom) isn't bent. I've had this sort of thing happen on a jigsaw that needed to be tapped back into square. Check the squareness of the saw with a framing square or a carpenter's square held against the blade and the bed of the saw with the blade guard open. Obviously, make sure the saw is unplugged before doing this.
Jul 28, 2011 | Makita Circular Saw - 15 Amp, 7 1/4in....
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Bed rails for Delta Martine Crib
I have this crib for my own child. I ended up buying a guard rail from Walmart. If you tie a knot in the strap after putting it through the rails and then tuck the disc between the side of the crib and the bottom of it, it seems to work just fine. Child has been using it as a toddler bed for well over a year now and there has never been an issue. Chiild is a restless sleeper too. So, I know it works.
Mar 01, 2009 | Delta Martine Crib
I need directions for the ellis simplicity 4 in 1 crib,
I have 2 versions of this crib...You take off the front rail... leaving the sides intact. You should move the bed rail up to the second holes...not the very bottom...or else the crib becomes even more Wobbly. After that you can attactch the toddlder rails to the 'side' rails...and one more screw (one on each) at the bottom of the toddler rail where there is a little metal bracket...attach that to the metal bed rail.
Feb 04, 2009 | Simplicity for Children 4 in 1 Ellis Honey...
Drastic Need for 2 Upper Tracks...
if you have the conversion kit for the crib to convert to a toddler bed, you should also have the white caps that go one the end of the guard rails for the toddler bed. I found with mine that they are the same ones as that are on the stationary side of the crib on the back side. if you do not mind having a crib with out a drop side you can remove both tracks and take those pieces and make it a stationary crib by merely following the way the rear side is put together. I have done it with mine as a guide was broken on mine. there should be four caps in the conversion kit that go on the two rails on the front side when you convert to a day bed. I figured out that they are the same as the ones on the back because you do actually use the ones off of the back side when you make it a toddler bed and put all four rail on.
Aug 15, 2008 | Graco Ultra Deluxe 5-in-1 4605 Crib
Jardine convertible crib instructions
Hi, I know it looks hard but It's really simple .just take out the screws that are on each side on the bottom and top 1 on the top and one on the bottom each side( 4 in total )(Sides not on the front) and that's it, the front part comes off and you save it for when you make the bed a full size bed wich that part becomes the foot board. Hope this information helps! Good luck!!
Jun 11, 2008 | Baby Gear
Baby Gear Logo
32 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
