Question about Air Tools & Compressors
I need a manual for a n60fn - Air Tools & Compressors
Where to download a stanley bostitch n60fn owners manual
Stanley Bostitch was purchased by Dewalt. Go to Dewalt web site for all the manuals. Good luck.
Feb 25, 2015 | Stanley Air Tools & Compressors
What degree nails are used in stanley bostitch n60fn nail gun
I've repaired many nail guns and I can tell you the Stanley Bostitch N60FN uses 15 guage nails from 1 1/4" to 2 1/2" long in the FN1500 series of Bostitch nails. Nowhere does SB or any of their aftermarket dealers list what the angle of the nails is. I do know most of the SB nail guns that come through for repairs are because of damage to them from using other than SB series nails.
Oct 01, 2012 | Stanley Bostitch Nail Gun
Stanley Bostitch N60FN finish nailer only pops when the trigger is pulled.
replace broken driver, or if driver is not broken replace the oring on the driver piston
Sep 10, 2012 | Stanley Air Tools & Compressors
Air is streaming out of the trigger mechanism.
I dont think it is your piston assembly, there is an o ring on the trigger valve assembly that is broken and would need to be replaced, If you need help getting it out let me know and I will guide you thru it. But while you have it apart look for worn o rings and now might be the time to replace them.
Feb 20, 2011 | Stanley Piston Driver Assy Bostitch N60fn...
How to set countersink on Stanley Bostitch model n60fn
There is a adjustment on the side of the nose on the safety. If it is stuck. The safety is probably a little bent
I have airnailerparts dot com
Dec 24, 2009 | Air Tools & Compressors
O ring for bostitch n60fn
What you need is part # ORK1 and you can order it online from The oring kit is $16.25. And if you also require a trigger valve assy it is listed on the page with the oring kit. The trigger valve assy is TVA6. Any questions please post back.
Oct 11, 2009 | Stanley Tools & Hardware - Others
Air is leaking around the trigger. N60FN. How do you replace it?
Yes, you have to drive out the pins. There currently is no rebuild kit. Depending on when your was built there are solutions though.
Carefully drive out the trigger pin first. Then the one retaining the trigger assembly. The trigger assembly is in there pretty good, carefully work it out. Once you remove it, there are two small steel pins holding it together. Remove those...careful there is a spring inside. You can see what's been compromised. Like I said, there don't make repair kits for these, but you can order a replacement assembly.
Good luck.
Aug 04, 2009 | Stanley Bostitch N88rh Framing Nailer...
My N60FN is leaking from around the trigger, where can I purchase a re-build kit?
The whole trigger assembly must be replaced.
Jul 23, 2009 | Stanley Bostitch N88rh Framing Nailer...
Help with Bostitch N60 air nail gun.
If it is a N60FN you will have to install a new trigger valve P/N TVA6. Any Bostitch service center should have them.
Apr 08, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
