Question about Drills
How do I remove the chuck from my Dayton 12" drill presas model 3Z993A?
  • 313 Answers
SOURCE: Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
Posted on Aug 19, 2008
protek480
  • 1723 Answers
SOURCE: caN'T REMOVE A 1/2'' CHUCK FROM A 13'' FLOOR MODEL CRAFTSMAN DRILL
Try heating it up with a torch and tapping it off with a punch
Posted on Jul 24, 2009
  • 44 Answers
SOURCE: remove keyless chuck on a 12 volt makita drill
There should be a Screw in side the end of the chuck were u put the drill bit in u will have to undo it back wards its got a left hand thread
Posted on Oct 23, 2009
  • 2976 Answers
SOURCE: hi, I have a Clarke Drill Press Model No:- CDP 12HBN
You can get a universal chuck key at Home Depot, Lowes and many other tool outlets. They have 4 different keys in one.
Posted on Nov 24, 2009
  • 302 Answers
SOURCE: dayton drill press, How do you remove the chuck?
If the spindle has a slot in it above the chuck and you can see the top of the chuck arbor in that slot then you need to get a wedged piece of steel commonly called a drift , insert in the slot so it bears on the top of the arbor and the top of the slot and hit it with a hammer. This will knock the tapered arbor loose from the spindle and it should fall out. Hope this helps you.
Posted on Jan 27, 2010
Tip
Chuck removal/cordless driver drills
For chuck removal first remove the chuck retaining screw which is LH thread. If this tool has a high/low selector shift to LOW and if equipped with a clutch shift to the drill only position. Find a bent handle allen wrench about the size of chuck capacity (the larger the better, less flexing) and insert the short portion into the jaws and tighten. Position the chuck on a workbench or block of wood with the longer portion at about a 30 degree angle so you can strike it counter clockwise with a hammer, strike the longer portion and the chuck should loosen (it is standard thread pattern) It might take a couple hits to remove. Chuck installation would be to reverse the above to seat the chuck and reinstall the screw.
on Oct 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Ryobi 12 volt drill/driver- cannot unlock the keyless chuck
replace the part you have taken out .
get a pair of stilson spanner adjust it so it goes around the chuck and do it and then it will ease off to do it up by hand
Sep 21, 2017 | Skil 2887 - 06 Factory - Reconditioned 18V...
Hello my drill bit holder is stuck open and the fingers that hold the drill bit won't come out of the housing no matter how hard I turn it.
If you go to this URL you will see a screw that is #1 in the exploded view.
http://www.ereplacementparts.com/ryobi-p206-18v-2speed-drilldriver-parts-c-7931_8051_8064.html
If the chuck on your drill is open you might be able to access this screw. It appears that this screw holds the chuck onto the drill and removing it might allow you to remove and then replace the chuck. I am not 100% sure of this, but it looks like a good place to start.
Sep 15, 2010 | Ryobi 18volt 12" Cordless Drill Model P206
How do I take the chuck assy. off a Makita 12 volt drill driver?
open chuck up all the way, and look down inside for a screw at bottom that needs to be removed, then twist it off.
Apr 11, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
I have a 12v makita drill and cannot remove the chuck i have removed the screw inside the chuck. lease help
The chucks on most drills are left hand thread. To be sure which way to turn the chuck check the screw the chuck will turn in the opposite direction.
Mar 29, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Dayton drill press, How do you remove the chuck? It has a Wilton 1/2 chuck 3z568 model
Jan 26, 2010 | Drills
Remove keyless chuck on a 12 volt makita drill
Oct 23, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Aug 18, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
51 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
