Question about Refrigerators
Ice maker not receiving water
Ice maker was making a noise and now it is not receiving water into the tray
roadbird383
  • 40 Answers
SOURCE: ice maker problem
Hi welem.....Is the bin arm in the down position??If not,the icemaker thinks its full and won't make or cycle any more ice.Other than that you may have a clogged or bad water solanoid valve.Located where the water enters the unit.
Posted on Nov 21, 2007
  • 358 Answers
SOURCE: water leaks from ice maker in ice tray.
When the ice maker calls for water it'll be filling for about 7 seconds if is more the ice maker inside control board is bad , but if there's water in the ice maker all the timeeven after or before it calls for water it means that the water valve (solenoid) that supplies water to the ice maker is leaking and you have to replace it.
Posted on Apr 27, 2009
  • 10865 Answers
SOURCE: Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 30, 2009
  • 136 Answers
SOURCE: ice maker is not making ice...no water to tray
there may be a sensor in the bin where the ice cubes drop into. It tells the ice maker when the bin is full so it stops making ice. Check to see if that sensor got bumped or moved or needs to be reset
Posted on Jul 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE ice maker, solid ice in ice maker
Many ice makers have an adjustment screw behind the front cover that shows plus or minus. Try the minus turn of the screw that should shorten the amount of time the ice maker fills. If electronic please call the company you purchased it from and explain the problem. Sea Breeze
Posted on Jul 24, 2009
Ice maker won't make ice
most times I see the tray and fill tube ice up its due to a leaky fill valve , this valve should close tight after filling tray , but sometimes they leak just slightly then everything freezes up in a block of ice
fill valves on most all units is located in back lower left corner , just follow the water line in the back of unit
Jan 15, 2016 | True Refrigerators
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
No water to the ice maker
Check that the pipe that fills the ice maker is not iced up. Also check that the solenoid on the back (where the waterline hooks up) is making a humming noise when the ice maker calls for water.
Apr 30, 2010 | GE GSH22SGRSS Side by Side Refrigerator
Frozen solid cube tray
Unplug the frig. Take a hair dryer and melt the ice tray. Then get a paper towel and soak up the left over water. hope this helped
Mar 30, 2010 | Refrigerators
Whirlpool freezer on top ice maker is making a grinding noise and is not making ice Apiece of ice is sticking out of the icemaker's tray. we left it in the off position a couple of days. when we returned...
You should have three screws on the side of the ice make. Two right above the tray and one below. Remove the screws and unplug a four wire connector.
When you reinstall it check for proper water fill. A low water pressure to unit or ice maker valve getting plugged up can cause a small cube to get stuck.
Jul 28, 2009 | Refrigerators
The ice maker is working alone, and makes a noise.
does it have a lever that you can lift up and turn it off since you are not using it to make ice.this will eliminate the noise which is trying to add water but you don't have the water line hooked up to it or your water solonoid is not letting water feed yhe ice maker tray. good luck,hope this works.
May 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
make sure the wire rod on the ice maker is in the down position in order for it to make and release the ice
Dec 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
