Code 13 on fridgidaire gallary washer - Washing Machines
Fridgidaire upright washer E41
Hello Marcee Peterson - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Electrolux washer displaying error code E5E
Communication problem. Check the wiring between the Main
Control Board and the Speed Control Board. Wiring bad, correct wiring problem. Wiring good, replace the Main Control Board. If the problem is not corrected, replace the Speed Control Board.
Dec 28, 2012 | Electrolux 134743500 Fridgidaire Washer...
I'm trying to disable the safety on the top load fridgidaire washer because it keeps malfunctioning and not finishing the rinse cycle.
This is something that is designed into the feature of this combo stack unit and cannot be bypassed at this current time - from my research.
Dec 24, 2012 | Frigidaire FEX831CS Top Load Stacked...
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Bleach will not dispense
Here is a tip that I wrote about the problem I found with my fridgidaire not dispensing fabric softner. Hopefully this will help you out...
Fridgidaire Washing Machine Fabric Softner not going into washer
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
Aug 20, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
E20 error code fridgidaire washer
A lot of times it is the strainer clogged at the pump. Hope that helps. Tim
Sep 02, 2009 | Frigidaire ATF6000ES Front Load Washer
My phone have gallary problem when i see file in gallary it is closed
Open the file from file manager instead of opening it from gallary.. If it doesn't help let me know.
Jul 11, 2009 | Nokia N70 Smartphone
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Nokia 2310 code error
if your mobile lock try 0000 or 1234, Or If U Change Default unlock Passward, Please go to Nokia Gallary In Your area and Ask them To Unlock Your Mobile.
If Your Sim card Lock their are two Solutions One is Call Cusomer care of vodaphone and ask them for PUK Code i.e. passward of Sim Card and another solution is if card rejected go to the nearest Vodaphone Gallary and askl them to unlock, it takes maximum 4 or 5 min.
May 19, 2008 | Nokia 2310 Cellular Phone
Washing Machines Logo
Top Washing Machines Experts
