Question about Photography
How to lock and unlock suitcase - Photography
Unable to unlock my new 19 degree aluminum suitcase
Was it opened at Customs ? If so, the lock may have been damaged.
Oct 01, 2017 | Photography
How to unlock suitcase
Pain in the *** but these are simple three tumbler locks. I am assuming it is what you have. If you start at 000 and go up in increments of 1 you can probably get this in about an hour. Other than that a screwdriver will break it open if you pry in at the locking mechanism.
Dec 01, 2014 | Samsonite Silhouette 11 Hardside Spinner
I have forgotten combination tomy suitcase and it is locked how can i get it unlocked
Start at 000 and go up one number at a time until it opens or reachest 999.. it will take some time. .. good luck.
I forgot my combination (three digits) to my champs suitcase
Try videos on the internet on how to unlock suitcases with three digit locks - there are quite a few. Good luck.
Aug 25, 2014 | Photography
How do you open the Ruby Red Melissa and Doug's trunki suitcase?
Trunki has secure locks that keep your child's favorite items safe inside for the ride. Simply slide the lock down to close and use the keys located on the ends of the shoulder strap to lock it in place. Unlock and lift the locks to open the suitcase again.
Aug 14, 2013 | Melissa And Doug Trunki In Ruby Red
Can not unlock combination lock of 'jeep' suitcase. Initial combo was 0,0,0. How can I reset the combination ?
What you want to do is just keep tension on the shackle, or the part of the lock that would open. With tension on it start at the opposite end and turn the numbers. You will notice that it will get "stuck" on a specific number. That's the last number in the combo. Turn the middle number till it sticks. Then the last. Tadaa! Hopethishelps
Feb 04, 2013 | Locks & Locksmithing
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
I have a somesonite 30in hardshell , uprite about 20 yrs old. has 2 key locks, as well as combanation center lock. question how can i set these locks so that, they are TSA excessable locks??? PLS. Help ...
You can have the locks changed but, that will cost almost as much as new luggage. They will have to be kept unlocked and a TSA strap will be needed around the suitcase.
Oct 07, 2010 | Samsonite Silhouette 11 Hardside Spinner
I have a VIP suitcase with three digit combination lock. Thouh I have not changed the code, it is not opening. It seems to have stuck. I have tried to open it even with a few earlier combinations or my...
I just opened mine. I also knew the the password and the suitcase wasn't unlocking. If you are all sure that u know the password. Then put some oil in the lock. wait for 1 hour... This will help. If it doesn't work then.. Put the lock code and push the clips manually with a pait or scissors or a small blunt knife.. Don't worry the lock is just stuck. After all it's a vip and not samsonite
Mar 21, 2009 | Baby Gear
Photography Logo
65 people viewed this question
Top Photography Experts
Are you a Photography Expert? Answer questions, earn points and help others
