Question about Sony Televison & Video
How to fix a flickering screen on a Sony bravia without factory remote
SOURCE: picture flickers
Check your power supply. Is it plugged in to the wall or a powerstrip? You might be overloading the powerstrip. Could be a source signal problem. Does this just happen when watching cable TV or does it do it on dvd's as well? Through the PC it is probably the viseo card,try reducing the resolution output from the computer.
Posted on Jul 01, 2008
mistersony
  • 320 Answers
SOURCE: sony bravia 46" remote control turns on the TV but no other buttons work
First, change the batteries on the remote with e new set of batteries. Check to see if you can bring up the menu using the buttons on the TV itself. Let me know what happens
Posted on Oct 18, 2008
SOURCE: Need remote code for TV Sony Bravia KDL-46W4500
I tried out a few of the numbers that were posted and the "0000" number worked.
Thanks anyway
Posted on Jan 03, 2010
welcomejee
  • 10594 Answers
SOURCE: i have a sony bravia davhdx274 but i no longer
Remote is necessary to use this sound system as there are many functions controlled by Menu on remote.
Required remote control is available in Sony Accessories Store for $52 under following part number..
148057011 RM-ADU007 REMOTE CONTROL
Thanks.
Posted on Feb 09, 2010
ladywinn
  • 5138 Answers
SOURCE: cant see the"picture freeze"on sony bravia remote.
Look on Facebook I Have a Defective SONY TV.
Posted on Aug 26, 2011
Does anybody know how to set a 32 inch Sony Bravia back to factory reset without remote
yes manually you can set press menu button then go to av setup & select factory setting from using vol+ & vol- with channel + & channel- buttons
Jun 21, 2015 | Sony Televison & Video
How to do a complete factory reset of a Sony Bravia KDL-32s5600 ?
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
Jul 07, 2014 | Sony KDL-32S3000 32 in. LCD Television
Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
Hi Freddy Pagan
I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
I can't turn off the demo mode on my sony bravia tv
Press Menu on tv remote, go to Settings and select Factory Reset and press enter button on remote, tv will reset to factory default settings and turn Off and On again itself, now select HOME mode instead of Shop mode to avoid demo mode and go by initial setup screen instructions.
Above are generic info about Sony bravia tv, let me know model number of your tv if you do not see factory reset option in settings menu.
Thanks.
Nov 08, 2010 | Sony Televison & Video
Sony Bravia KDL-32M3000 Has sound, no picture, back-lights are on, red lines flickering across the screen which seems to prove there is video present. I'm thinking T-Con board. I ask this question because...
There is no way to really check a T con without a lot of test equipment, only thing that is serviceable on that board is the small fuse that is by the LVDS connector...
Dec 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
Apr 18, 2010 | Sony Bravia KDL-42V4100 42 in. LCD TV
Tv picture is pink with vertical lines sony bravia 32 inch XBR
it sounds like a bad t-con board. this board my not be sold without geting the whole screen. the t-con borad is at the top of the screen and connects to your main board
Apr 15, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My Sony Bravia KDL-40D3000 no longer responds to the IR remote. I also have a 46 inch Bravia, and the remote does work with it. The front panel controls work okay. The remote worked for about 2 years, then...
Had the same problem. The infrared receiver quit working. Could not use the factory remote or the cable remote. Simple fix- I just cleaned the infrared receiver. Both remotes now working.
Mar 27, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Flickering screen
Two models of the 46 inch Sony Bravia have a screen flicker problem. On my 2008 model, starting from cold, it lasts for 5-10 min, on LHS of screen. The Telefix tech who visited said this is common with these models (46in only), a new panel is needed. Sony provides warranty on this fault for 3 yrs, so you do not need extended warranty to claim. Discuss your case with Sony or Telefix.
Jan 03, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How to do a complete factory reset of a Sony Bravia KDL-32P3000
Just talked with Sony Support today.
It seems that Sony in Denmark had sent out new software updates (over DVB-T) but also some wrong TV's got updated as well. This caused my DVB-T tuner to not function anymore so I wanted to try a factory reset and it fixed my problem.
So I was instructed on how to do this. I have a Sony Bravia KDL-32P3000 (which should be similar to the U3000 and S3000 as well).
This is how to do a factory reset of your Sony Bravia KDL-32 P/U/S-3000 TV.
PLEASE BE VERY CAREFUL WITH THE SERVICE MENU, YOU CAN EASILY CAUSE YOUR TV TO MAL-FUNCTION!!!! IF YOU FOLLOW THIS GUIDE IT IS AT YOUR OWN RISK!!!
Set your TV in standy (use the green power butten on your remote), RED standby LED is ON on your TV.
Now press these buttons in this order on your remote (pointing to the TV).
i+
5
VOL UP (+)
GREEN POWER button
NOW BE CAREFUL! Dont press any keys just for the fun of it!!! IT MAY DESTROY YOUR TV.
You should now be in the service menu. It will show up as some green letter/numbers spread over the screen (mine are a bit hard to see/a bit faded). In the upper right corner you should have 2 letters TT (two t's).
Now carefully press key 0 and then key 8 on your remote (they should be shown on the screen after the two TT).
Now wait a little while (more than 10 seconds) and your TV should reset with factory settings, just as if you had just brought it home from the TV store.
Best wishes,
Mads
May 14, 2009 | Sony KDL-32S3000 32 in. LCD Television
Televison & Video Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
