Question about Hannspree Computers & Internet
Hi I have a Hannspree HSG1279 and cant factory reboot, tried using keys but no luck also went into settings and used backup restore still no luck. any ideas please
  • 37 Answers
SOURCE: dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
Posted on Jan 06, 2009
SOURCE: My original 80GB Ipod gets an error code 1437
I'm not really sure about my solution but i did it and it WORKED so well. When you catch some error like it, you just leave your Ipod alone, wait until the screen turn black and go back to charge it. I really WORKED for me when it leave it alone and thought that it already died. I hope u will it through it.
Posted on Apr 07, 2009
  • 31 Answers
SOURCE: i cant restore my factory setting of my n95 china phone please he
use 1122 i'll restore your phone factory settings
Posted on Jul 08, 2009
  • 617 Answers
SOURCE: I have an NEC powermate ML7 that I want to restore
This is a walk thru on the use of the recovery portion of your drive.
Posted on Jan 04, 2010
Testimonial: "Very specific link provided. Thanks!!"
  • 16 Answers
SOURCE: how do i restore my compaq presario laptop to factory settings
If u Create a restoring poit & use a original copy operating System then u restore it nahi to operating system repair kar le.
if u want to restore ur BIOS then open ur Bios from F2 & Load its default settings by its given instruction.............
Posted on Apr 13, 2010
Hi Hi i forgot the password to my samsung galaxy note 10.1 2014 eddition
No problem follow the steps bellow to factory restore you Galaxy note 10.1
- Turn Off your Samsung Galaxy Note 10.1 device.
- Wait for 10 seconds, Then move to the next step.
- Press and hold Volume Up key + Power key.
- Keep pressing the above keys until the Samsung Logo appears,Then release Power key only.
- When you see Factory reset / System Recovery menu on screen release the Volume Up Key.
- Use Volume Down key to select Wipe Data / Factory Reset option.
- Use Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
Notice: The Hard Reset / Factory Reset operation will delete anything that are saved in your phone's internal memory, So make a backup of your data in case you can access them.
Feb 05, 2018 | Samsung Cell Phones
Will not switch on Hannspree tablet HSG1279
I had the same problem, you need to reset the Android system by holding in both the volume up button along with the power on button together, once you see the Handspree logo, release. you should boot into the recovery system, you now can reboot the system by using the volume buttons and the power button to select. you could also contact the Handspree help line on 0871-6641 811, but they will only tell you the same this helps.
Dec 27, 2013 | Hannspree SN10T1 101 Tablet
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Jul 25, 2011 | eMachines E620-5885 Notebook
How do you reset to factory settings on the gateway ZX4931-31e
Click on Start -> All Programs -> Scroll down to Gateway (or type Gateway in the line) -> click on Gateway Recovery Management -> click on rider "restore" -> click "Restore System to factory default".
May 05, 2011 | Gateway ZX493131e Notebook
Restore Factory Settings on Dell Latitude D620 (refurbished)
Restart your system. As soon as the computer reboots and when you see the blue line on top of the screen with a label that the time that you have to hit ctrl+F11. Once Dell PC Restore appears click on the restore button.
Best of Luck
May 30, 2010 | Dell Latitude D620 Notebook
Issue with full PC restore on Vista ASUS G1 notebook
Where is the backup stored? Most OEM backups of the OS write to a partition on the hard drive, if you did a recovery with the DVD it may have overwritten the recovery partition, hence why the option is not available.
Nov 09, 2017 | ASUS G1 Notebook
Reboot my Acer Notebook
Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
Mar 05, 2010 | Acer Aspire 3100-1405 Notebook
I downloaded the US-Canada map update and now i turn my TomTom on and it says i cant us that map and now i cant even use the device is there someway i can restore the device back to default?
You could try reseting the device
1) Turn the device off.
2) Press the Reset button located on the bottom of the device (you'll need a paperclip to do this).
3) Turn it back on. See if it works now.
1) Do you have Tom Tom Home set up on your computer?
2) Did you ever make a backup?
If so, now is the time to restore from backup.
To restore factory settings:
1) Turn on Show All Menu Items in the Preferences menu.
2) Tap the Reset Factory Settings button (it's on the last screen of the Preferences menu).
Best of luck to you.
Nov 24, 2009 | Tomtom One XL GPS Receiver
Dell laptop inspiron 1000
2. HDD (hard drive)
Jan 06, 2009 | Dell Inspiron 1000 Notebook
Computers & Internet Logo
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
