Question about Coffee Makers & Espresso Machines
The single cup brewer heats up the water but it doesn't come out. I cleaned it and descaled it but it still doesn't work. It is only maybe 4 or 5 months old.
5 Suggested Answers
  • 28 Answers
SOURCE: Keurig B60
Check the needle inside the k-cup holder to ensure it is not clogged. You can completely remove the k-cup holder by pushing up from the bottom (where it dispenses into your coffee cup). Then rinse it out with hot water using your kitchen sink sprayer. The manufacturer also recommends inserting the tip of a small paper clip into the needle to push out any debris if needed. Then replace the k-cup holder by aligning the arrows and snapping it back into place. Next try to brew your regular cup of coffee and see if that fixed the problem. Hope that worked for you...Best of luck!
Posted on Feb 07, 2010
  • 60 Answers
SOURCE: single cup keurig brewer. machine heats up but no
Call Keurig 1800 Cup Brew
Posted on Mar 23, 2010
SOURCE: Not making complete cups
There is a sharp pin that punctures the K-cups. Take a toothpick or pin or paperclip and gently put it through the hole in the top of the pin. Apparently it gets clogged, and that's what prevents the flow of water into the K-cup, and causes the water to back flush into the reservoir
Posted on May 04, 2010
  • 239 Answers
SOURCE: Breville stainless steel brewer. 1
Hello, sorry to hear about your problem.
Have you tried reseating the water tank. Breville are aware of this problem. After some research and given that you have already cleaned the coffee maker, try reseating the water tank. Give it a good wiggle and make sure it is flush against the unit by pressing it in. I don't have your specific model number so I don't know where the microswitch is situated but essentially if there is one it needs to be made by the tank.
Short of this Breville should be very understanding about the defect as it is very very common and after a year I think its not a bad prospect to ring them, complain and express your disappointment. Quote statutory rights at them too, as it is not unreasonable for one to expect a coffee maker to last in excess of 2 years, especially given the reputation of Breville!
Just because it is out of warranty doesn't mean they are unaccountable!
Hope this helps and good luck.
Jim
Posted on Oct 11, 2010
I need to descale my icoffee single cup brewer but other sure how to do it., Any idea?
run white vinegar and water through the machine with no coffee, maybe even a number of times, finish with plain water cycles
Jan 15, 2018 | Coffee Makers & Espresso Machines
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
My keurig b60 says prime
This can go out by draw out some hot water. However if this happens very often then you need to perform a descale.The brewer should be descaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. Descaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend descaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The descaling process involves using 48 ounces of undiluted white vinegar. Learn how to descale your brewer.
Feb 24, 2012 | Keurig B60 Coffee Maker
Coffee maker will not make but one size cup
If your brewer is not brewing the full amount selected, it may be caused by the following:
  • The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Jul 04, 2011 | Keurig B60 Coffee Maker
1. It sometimes doesn't give me a full cup as per the setting. 2. It was hardly working and I descaled with vinegar - it worked while I cycled the vinegar through but then quit working entirely
Then try also this
http://www.youtube.com/watch?v=DqRs4Ott21s
Jul 04, 2011 | Keurig Special Edition B60 Coffee Maker
We have just descaled our Platinum unit and reset all the functions. When attempting to make a cup of coffee, it says it is brewing, but NOTHING is happening. What do we do?
Then try also this helpful tip
Jul 04, 2011 | Keurig Platinum B70 Coffee Maker
Display reads descale, what can i do to fix this
Descaling the Brewer Mineral content in water varies from place to place. Depending on the mineral content of the water in your area, calcium deposits or scale may build up in your Brewer. Scale is non-toxic, but left unattended, it can hinder the Brewer's performance. Descaling your Brewer helps maintain the heating element and other internal parts of the Brewer that come in contact with water.
NOTE: Do not use water that has been treated by a 'water softener'. The increase in sodium levels in the water can cause scaling in the brewer and hinder its performance.
The Brewer should be descaled every 3-6 months to ensure optimal performance. It is possible for calcium deposits to build up faster, making it necessary to descale more often. This Brewer is equipped with sensors to detect when scale buildup is interfering with the performance of the Brewer. When this is detected, the LCD screen will indicate 'DESCALE'.
NOTE: The Brewer will continue to operate even when the LCD screen indicates 'DESCALE'.
However, if you do not descale the Brewer soon after it is displayed, continued scale buildup could damage the Brewer. If this occurs, 'DESCALE' will begin to flash, alerting you to the potential damage to the Brewer if you do not descale immediately. Promptly follow these steps each time the LCD screen indicates 'DESCALE' to ensure that the Brewer functions optimally.
1. 4459906401_be71bd1933_t.jpg Empty the Water Tank and refill it with vinegar, filling up to the MAX mark on the water tank viewing window. 2. 4459906749_2d2d8c9472_t.jpg Place a 12 oz. or larger ceramic cup (do not use a plastic cup) on the Drip Tray. The Drip Tray and Drip Tray Plate can be removed to accommodate taller mugs and travel mugs. 3. 4460685206_41a39b1eab_t.jpg Select the largest brew size (11.25 oz. serving) by pressing the button on the control panel. 4. 4460685734_41eef702a7_t.jpg Run a cleansing brew without a K-Cup®. Pour the contents of the cup into the sink. 5. 4459906625_e723d37450_t.jpg Repeat the cleansing brew process until the Water Tank is empty, pouring the contents of the cup into the sink after each cycle. Remember to raise and lower the Safety Locking Arm between each cycle so the control panel buttons illuminate. 6.
Let the Brewer stand for at least 4 hours while still on. 7. 4459906401_be71bd1933_t.jpg Rinse the Water Tank thoroughly and fill with fresh water. 8. 4459906749_2d2d8c9472_t.jpg Place a 12 oz. or larger ceramic cup (do not use a plastic cup) on the Drip Tray. 9. 4460685734_41eef702a7_t.jpg Run a cleansing brew without a K-Cup®. Pour the contents of the cup into the sink. 10. 4459906625_e723d37450_t.jpg Repeat the cleansing brew process until the Water Tank is empty, pouring the contents of the cup into the sink after each cycle. You may need to perform additional rinse cycles if you notice any residual taste.
Remember to raise and lower the Safety Locking Arm between each cycle so the control panel buttons illuminate. 11. 4443328562_50d07cb55b_t.jpg Disconnect the power plug from the wall outlet for at least 15 minutes, then re-plug the power cord into the wall outlet. The machine is now ready to use.
NOTE: If the LCD screen continues to indicate 'DESCALE' after completing the process, repeat the 'Descaling the Brewer' process.
Check out this link for support on your unit.
http://brevilleusasupport.com/product/bkc700xl#2044
May 25, 2011 | Breville BKC700XL Stainless Steel
Water does not completely flow through
sounds like it is time to maybe do a descaling to the unit.
put about 1 cup of white vinegar in the water and let it do a cycle -- do it one more time and see if this clears it up,, then do 2 to 3 cycles of fresh water to clean out the vinegar. this should clean the unit to new working condition.
let me know if you are still having troubles -- as there are a few other things that might be causing the problem.
c...
Feb 15, 2011 | Keurig Ultra In Home Single Cup Brewer...
Coffee maker not brewing Water heats up but then no coffee comes out
9 times out of ten , the needles on the the k-cups are plugged so water is not allowed to pass. clean with toothpick , small nail, etc.
Feb 12, 2010 | Keurig Elite B40 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
