Question about Lincoln Welding Tools
ENGINE REMOVAL ON A LINCOLN PORTABLE WELDER, WITH A 16 HP BRIGGS& STRATTON ENGINE, THIS IS A 200 AMP AC/210 DC WELDER. i HAVE TO FIX ARMATURE,COLLAR WHERE BRUSHES RUN,ONE OF THE COLLARS HAS SPLIT IN HALF.
  • 24 Answers
The collar is a slip ring, you remove the engine and rotor together and then remove the rotor from the engine.
Posted on Sep 18, 2009
Briggs & Stratton engine model # 4455770435E1, need to find out what part number to order to fix alternator? Told our "stater" was bad?
The alternator (P/N 592831) should put out around13-14 volts DC with no load (other than charging the battery. If the voltage drops only when the deck is engaged but not when the lights are on it could be a connection to the mower clutch causing excessive current draw. I suggest covering the fundamentals such as ensure the battery is healthy, ensure all connections are clean and tight before condemning the stator. then and only then would I remove the flywheel to inspect the stator.
Aug 16, 2014 | Briggs & Stratton Briggs Stratton Intek V...
GIANT WSE 200 amp ac dc tig welder
Buy a new circuit board as it will be cheaper in the long run as the solder has damaged vital parts on the board. It will take a lot of frustration in fixing all parts .
Apr 04, 2013 | Welding Tools
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
Thermadyne predator has one cylinder not firing
Check or replace ignition wire, spark plug spark plug coil. Run a cylinder compression check. Should have same compression on both cylinders. If not, burnt valve, or flat cam lobe.
Sep 18, 2012 | Hobart Welders 500545 Champion Elite 11000...
I have a hobart champion 16 and it will barely arc it will not make a weld it went from welding fine to doing this.
Could be something as simple as worn brushes, dirty slip rings, or a bad bridge rectifier. If you know how to check them, these are all something you could fix. If it's anything beyond those, you're best bet would be take it to a repair facility. I repaired welders for 18+ years. (just an FYI)
Jan 04, 2011 | Hobart Welders 500545 Champion Elite 11000...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln Welder Generator Oil Question
Better late then never! im-308 total lube oil is 4 pints for a briggs and stratton engine
and 3.5 for an onan engine with filter change.
Note: an internal kill switch will shut down the engine if the oil level drops below a minumum
operating level on the onan engine only.
on your welder use a multi-viscosity sae sj grade or better oil. recommended is 10w-30.
if you work in cold environments use 5w-30 oil , it's thinner and will flow easier
during cold starts. Synthetic oil is better. just more expensive. change oil at least
every 100 hours for better performance. good luck!
Aug 19, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
Welding Tools Logo
998 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
