Question about Pro Computers & Internet
How long will a Surface Pro 4 last? - Pro Computers & Internet
My surface pro 3 isn't turning on
Is it plugged into the charger?
It could have crashed.
Try holding the power button down for about 10 seconds, and then attempt to turn it back on. See what happens.
Apr 15, 2016 | Microsoft Surface Pro Tablet - 3rd gen...
Reset my w10 pro.
Step 1: Make sure Surface is shut down and plugged in. Step 2: Insert the USB recovery drive into the USB port on Surface. Step 3: Press and hold the volume-down button while you press and release the power button. Step 4: When the Surface logo appears, release the volume-down button. Step 5: When prompted, select the language and keyboard layout you want. Step 6: Tap or click Troubleshoot, tap or click Refresh your PC, then tap or click the target operating system you wish to refresh. Step 7: On the Refresh your PC screen, tap or click Next, then tap or click Refresh.
Surface restarts and the Surface logo displays while the refresh process completes (this can take several minutes).
Feb 01, 2015 | Computers & Internet
How do I set ao smith pro max model ect 52 on vacation mode
No vacation mode in this heater. I have used this for last 5 years.
Dec 18, 2014 | AO Smith A O Smith Water Heater Hot...
How can I troubleshoot an Asus monitor that won't display an image?
check you surface pro display setting.
check if it is enable to give signal to 2 display image of surface pro
Aug 31, 2014 | Computers & Internet
Why won't my hp elitebook 8540p speakers work while in the docking station, connected only to external mouse and monitor?
You can switch audio playback between the docking station and your Surface speakers. Here's how:
Step 1: Swipe in from the right edge of the screen, and tap Search.
(If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Search.) Step 2: In the search box, enter manage audio, and in the search results tap or click Manage audio devices. Step 3: Next, do one of the following:
  • To play audio through the audio port on the docking station, tap or click Speakers (CNXT Audio).
  • To play audio through the Surface speakers:
    • On Surface Pro 2 or Surface Pro 3, tap or click Speakers (Realtek High Definition Audio).
    • On Surface Pro, tap or click Speakers (2-High Definition Audio Device).
Step 4: Tap or click Set Default, and then tap or click OK.
http://globalvision.com.vn/vn/may-in-ma-vach-pc-3.htm
Apr 27, 2014 | HP EliteBook 6930p Notebook PC
Microsoft surface pro black screen
These get stuck- try holding the power button and the volume up for about 10-15 seconds and it should reset itself.
Dec 30, 2013 | Microsoft Surface Pro
Burners output seems "weak", is there a valve that regulate gas flow and if so can it be adjusted?
Yes it can be . Contact your utility company. They can make the adjustment. They have a vested interest and a responsibility in this .
Jan 27, 2013 | Thermador Pro Harmony PRG304GH 30"...
Is it true that you have to change the surface of your ramp once or twice a year after your ramp is complete?
It all depends on the surface Skatelite lasts well over 4 years and so does polyboard if you look after it.
Jan 13, 2013 | Sport & Outdoor - Others
Green blinking light will not go off
You probably have bad capacitors in the DM board assy. These are going to have to be replaced. There are also surface mounted fuses, two of these inside this board. If you do not know how to solder on printed circuit boards, and work with surface mounted components, play it safe and call out a pro to assist you in this repair. Good Luck.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Red line on last quarter of photos
I assume that the red line is not on the photos themselves (make sure this is the case - if they're scanned photos, it might be a scanner problem). If this is a 4" by 6" paper, set it in the printer after bending it in the opposite direction. 1) Set a sheet of paper on the printing side of the paper to be printed on. (If the print surface is touched by hand, the print surface may be soiled by skin oils, and the print quality may deteriorate.) 2) To bend the paper, hold the paper in a rounded shape for about 10 seconds. 3) Remove the paper not to be used in printing, and confirm that, when laid flat with the print side up, the center of the paper to be printed on is raised between 2 to 5 mm (0.2 in.) . 4) The curled paper to be printed on should be set in the printer, and printed, sheet by sheet. Canon recommends using Photo Paper Pro PC-101S 4" x 6" sized paper. When using PC-101S, printing is performed at the center of paper and streaks or uneven printing is avoided. If this is an A4 sized paper, try using Photo Paper Pro PR-101 paper, and make sure that the printing quality is set to "high" or "fine". If nothing helps, I would suggest trying a new ink cartridge. If you still have this problem and nothing solves it, call a repairman.
Apr 09, 2006 | Canon BubbleJet i560 InkJet Printer
Computers & Internet Logo
12 people viewed this question
Top Pro Computers & Internet Experts
k24674
Kenni Lewis
Level 1 Expert
Tom Chichester
Are you a Pro Computer and Internet Expert? Answer questions, earn points and help others
