How long will a typewriter last? - Office Equipment & Supplies
Standard manual corona typewriter: spacebar not working
There is an escapement type mechanism in the back of the typewriter, chances are, the escapement mechanism is out of movement or misaligned. Check the spacebar if something is caught underneath or over one of the linkages.
Jan 16, 2014 | Office Equipment & Supplies
How can I get my typewriter back to its intial settings
There is no keystroke pattern to reset the EM series typewriter. There are two methods to reset this typewriter.
1.You can reset the daisywheel and remain on the same line of type, simply lift the top cover and then close it back down. The carrier will move to the left, reset the daisywheel and return to the last space typed.
NOTE: This will not affect the format settings (bold, underline, etc)
2.If you want to abandon the current typing position; turn off the typewriter, wait 10 seconds for the power supply to reset and then turn the typewriter back on. The typewriter will reset and the carrier will return to the beginning of the current line.
NOTE: Turning off the power will restore the format settings to standard default settings (bold, underline, etc).
Mar 15, 2013 | Brother EM-630 Typewriter
My typewriter keeps returning to the same line.
If it will space up with the platen knob the plastic gear on the feed motor is broken. The last time I replaced one the motor and gear was 35.00.
DickyO
May 02, 2011 | Brother SX-4000 Typewriter
Why does my typewriter not print? It worked when last used. If I keep hitting one of the keys for a long time, it will start to print.
If the carrier is moving but no print you brobably have a broken print solenoid cap. We sell them for 20.00 includes shipping and instructions,
If nothing happens at all you probably have a bad keyboard.
DickyO
Dec 23, 2010 | IBM Wheelwriter 30 Typewriter
Typewritr Olimpia as a printer
At one time there was an interface available for many typewriters contact Nakajima @ 800-809-7138 they made the last Olympias.
DickyO
Jun 08, 2010 | Olympia Standard 300 Typewriter
How do I use my repeat key on my Swintec model 2640 typewriter
The repeat key just types the last letter you typed over and over
DickyO
Jan 14, 2009 | Swintec 7040 Typewriter
IBM Sel. II will not power up
It sounds lika the motor belt broke not an eazy fix see a typewriter repair person
Dec 06, 2008 | Office Equipment & Supplies
Nakajima AE-830
The typewriter is set in P.S. mode instead of 10 or 12. This switch is in lower left corner of keyboard.
Oct 02, 2007 | Nakajima AE-830 Typewriter
13 people viewed this question
jasbo
jasbo
