Question about Dryers
How long will a dryer last? - Dryers
Whirlpool dryer model wed7300xwo gets to last 3 minutes then trips breaker
generally the last 5 min are a cool down part of the cycle and there are no elements energized at that time, which cycle are you using and how long do you set the time for
Dec 01, 2013 | Whirlpool GEW9250 Electric Dryer
Kenmore dryer 79690272900
This is too broad a question. Does the dryer light go out when you press the button? It should, but the switch could still be bad. Is the motor receiving power? If yes, replace the motor. Is the belt in place so that the belt switch is working? Test the belt-switch with meter. Lastly, is the main control (logic) board still functioning? Consider this last.
Nov 27, 2013 | Dryers
Thermal fuse in dryer keeps blowing out
Hi Janet Douglas
Check to make sure your vent is clear, this can cause the overheat problem and blow the thermal fuse.
Also check to make sure the blower is not full of lint also as this can cause the same problem you are having happen.
Another thought:
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element and thermal can burn out very quickly.
Please take time to rate me
Bud
Oct 14, 2012 | Whirlpool Dryers
Siemens Condensor Dryer E46-38. After a few
Mine is 4 years old and the pump went within 8 months! The dryer has had 6 new pumps in total! It was last fixed 6 months ago and now playing up again! I dont even constantly use my dryer! I am very disappointed with Siemens now, my last dryer lasted me 10 years and it was constantly on the go when my children were young! Here comes, tomorrow I have got to book another repair! No more Siemens for me.
Oct 20, 2009 | Siemens Dryers
Series 80 gas dryer. Turn on and flame only lasts few mins.
Intermittent contact inside one of the gas valve coils. Replace. Part number 279834.
You can order them at AP Wagner. Use coupon "New10" for 10% off
Oct 16, 2009 | Kenmore 75944 Gas Dryer
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Sep 08, 2009 | Dryers
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
I ran the dryer last week. Today, i find moisture
if your dryer vent is bent or to long this will happen
Feb 24, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer won't start
I believe you have lost a leg of power.Check you breaker and then the wiring in the back of the dryer.
Jan 09, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
