How long will a washer last? - Washing Machines
NEPTUNE WASHER WILL NOT SPIN UP TO SPEED ON LAST CYCLE
sounds to me to be the programmer (mine went down last week) i bought a new machine as the part was a joke cost wise. if its old your probably find that other things will go wrong soon. now i have a fresh 3 yr warranty. would advise the same for you
Mar 08, 2014 | Maytag Neptune MAH5500B Front Load Washer
No pressure on Honda 2400psi pressure washer
spill valve aka unloader valve is stuck needs to be cleaned and lubricated with grease re instaled
Jun 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
LG Washer leaks from front door
search the parts stores on internet then check ebay i find many times the common parts such as door gaskets can be had cheaper on ebay
Sep 29, 2009 | LG WM-2277HW Front Load Washer
The washer was one last rinse and stop did't drain?
Generally a bad drain pump or a clogged drain pump or drain hose. Have a look and let me know what you find.
Benjamin
Aug 09, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
The Timer Window shows FL and the washer stops after filling.
I unplugged the washer for 20 minutes, plugged it back in, the same FL message appeared, so I slammed the door (as a last effort to attempt to overcome the problem of door failing to close before I would decide to call a repairperson). Following the sound slamming of the door, the washer has worked just fine through the last five loads.
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Nov 17, 2008 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
