Question about Crafts & Hobbies
How long will a plane last? - Crafts & Hobbies
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 16 Answers
If you take care of it, keep it sharp and stored correctly, it should last a life time.
Posted on May 11, 2017
How to adjust
Those are funny little planes - they're wicked handy when you need one. I like mine a LOT.
They ARE coarsely built, not a "fine" tool, but they do a fine job.
Loosen the little screw SLIGHTLY, then either bump the rear of the iron (to extend it more) or the rear of the plane (to extend the iron less) against a piece of softwood (bench, sawhorse, 2x4, hammer handle). When it's where you want it, tighten the little screw again.
Adjust the plane's mouth (assuming that you're using it as a bullnose plane, not as a chisel plane) by loosening the big screw, then just sliding the bullnose front & rear.
Remember - planes are meant to SHAVE wood. The iron should NOT take off a thick shaving, it should take off a shaving no thicker than one sheet of toilet paper. The iron should BARELY peek out from under the plane.
Jan 14, 2014 | Stanley 12 - 975 Contractor Grade Bull...
Broke 4 belts in 3 months
Check to see if your pulleys are all in the same plane. Take a ruler or other straight edge and put it on the front of one pulley and then extend it to the nearest pulley and make sure that the line up. Sweep the straight edge over the next pulley while holding it firmly on the first pulley to verify that they are both on the same plane. Repeat with all pulleys.
Apr 05, 2013 | Dryers
Cant get my 3" block plane back together
Pretty hard to help you directly. 3" is a pretty small plane if you mean the length of it, and pretty big if you mean the width.... try Google images for "plane buck", maybe a picture will help. Good luck.
Nov 05, 2012 | Craftsman Block Plane 158 658 in 37177
Maytag Bravos XL roars like a plane
Why is maytag not doing something about this issue. I'm having the same issue with a 2 1/2 year old washer. I'm not going to fix it or buy another maytag. I'm going fisher paykel. My last one lasted 22 years.
Aug 23, 2012 | Washing Machines
On a round trip of 400km,a pilot wants to determine the airspeed of hiis light plane. He flies the entire distance at the same airspeed for the first 200km a steady headwind slows him down by 30km/hour....
v will represent plane's airspeed.
We can divide pilot's trip in 2 parts:
  1. first 200km, when he is flying with speed v. The time it takes him to fly this part of trip is t=200/v
  2. last 200km, when he is flying with speed v-30. The time it takes him to fly this part is 200/(v-30)
The time it takes him for second part of trip is also equal to 1.5-t (because entire trip takes 1.5h), so now we can write equation:
1.5-t=200/(v-30)
We also know that t=200/v so we substitute that into equation:
1.5-200/v=200/(v-30)
To solve this equation we multiply it with v*(v-30)=v^2-30v first. We get:
1.5(v^2-30v)-200(v-30)=200v
Now we get rid of brackets:
1.5v^2-45v-200v+600-200v=0
or
1.5v^2-445v+600=0
This is quadratic equation, so we get 2 solutions (sqrt= square root):
  1. v=(445+sqrt(445^2-4*1.5*600))/(2*1.5)=295.3 km/h
  2. v=(445-sqrt(445^2-4*1.5*600))/(2*1.5)=1.4 km/h
We know that only v=295 km/h is solution because if 1.4 km/h was solution that would mean that second part of trip plane was flying with speed 1.4-30= -28.6 km/h, so that would mean he was flying backwards (which we know he didn't because it's round trip). Speed 1.4 km/h is also not physical solution, because plane wouldn't be able to take off with such small speed :)
Sep 08, 2011 | Casio ClassPad 300 Calculator
I assembled my new Super Cub RC plane and when I put the battery in the plane the elevstor snd rudder would move, but when I pushed the throttle up it didnt work. I am new to this and troubleshot it many...
G o back to your manual. I had this problem also. The procedure must be followed properly. First, make certain your throttle is in the off/down position. Second, turn on transmitter. Third connect battery. Once you place the battery in the enclosure and lock the cover you should be working properly. Last but not least, when finished flying, remove the battery BEFORE powering off your transmitter. You must follow these steps. You can NOT leave the battery in the plane when not in use.
Jul 21, 2011 | Hobby Zone Hobbyzone Super Cub Propeller...
How do I plane the edge, end and surface of a board? how do i find a hand saw for ripping a board?
Are your arms big? Good, cause that is how you do it. With a lot of muscle. They have too many power tools out there now to make it easier. But if you want to do it the old way, you will need a handful of planes, not just one block plane. You need a couple of jack planes, smoothing plane, and scraper plane, to get a nice surface, the jack plane, 12 -14 inches long will go right over the bumps and flatten those edges right out, Keep it square to the edge. Look by eye and use a square to check. Your end grain can be done with your block plane, get it in a vise and take little cuts. Your surface is the tough one, it takes a sharp iron and a steady hand to surface a board, some woods don't like being surfaced, some do. Again, start out with the scrub plane, 8-12 inches, and run it against the grain to smooth, then the jack plane with the grain to flatten, then the scraper to finish. Rip saws are hard to come by, the teeth are at a 90 degrees to the saw. and wide, and you need big arms. The japanese saws have both edges on their saws and they work great. But you can't beat an electric planer. Hope this helps.
Apr 06, 2010 | Craftsman 7 in. Plane Block
Crafts & Hobbies Logo
823 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
