Question about Boating
How long will a boat last? - Boating
Witch model of boat do i have with ser no LAR75995H405
Sounds like a 2005 Larson. All boat manufacturers go by the last two digits to identify the year. The 180 or 186 is the model number which normally corresponds to the boat length: 186 meaning 18'6" and 180 meaning 18 feet.
Dec 23, 2014 | Boating
What year is my Lowe boat serial 15 0526809
It doesn't sound like enough digits but the manufactures us the last two digits to identify the year. So if the numbers are correct then your boat is a 2009
Dec 21, 2014 | Boating
What year is my boat. ?
You need to locate the serial number which is usually located on the back right side of the boat. It will be the last two numbers of the serial number.
Oct 06, 2014 | Boating
What year model is a vip viscount ski boat with serial number 9c264g788
on all the boats that have a VIN number the last two digits of the VIN is the year of the boat so if the number that you listed is a VIN number then it is a 1988.
Aug 11, 2014 | Boating
Cuts out
15 minutes is a reasonable time for a low cost RC boat. Is it cutting out because of low battery voltage?
Jun 02, 2010 | New Bright Radio Controled 18" 6Volt Sea...
I need wiring diagram for boat 1993 Bayliner jazz engine: mercury 90 hp 3 cylinder 2 stroke jet serial no:oeo31008
can't start my 1993 bayliner 1400 jazz. replaced key switch, kill switch today. I got the boat last week running.
Sep 24, 2009 | Boating
I need year of starcraft boat
If you find the hull identification number which is always stamped on the right side of the transom then the last two numbers indicate a year. Ex. BUJ5C45208 Would be a 2008.
Jul 09, 2009 | Boating
Why are Aluminum Fishing Boats the Best Fishing Boats?
A timber boat is high maintenance. Trust me, I've had quite a few. You're always sanding timber, varnishing timber, repairing timber and lots more. Now if you're happy to be doing that then that's great, but recognize that's the price you pay for a great looking timber fishing boat. And a timber boat is often heavy, and will not last well, particularly if you aren't as diligent with your maintenance as you could be. And they puncture easily when you hit something, as I did last week. But if you're not an enthusiast for working on boats then timber isn't your best choice. What you want in a fishing boat is this. It needs to be tough. It needs to be low maintenance. It needs to be puncture resistant. It needs to last forever without spending hours working on it. It needs to be easily repairable. And it needs to be cost effective. For me the best choice fishing boat is an aluminum fishing boat. Aluminum has properties which make it the perfect material for building fishing boats. It is very light and strong for it's weight, and can be easily welded, so is ideal for both building and repairing. It is extremely long lasting, and is very resistant to puncture. Now of course that doesn't mean it can't be damaged, as it can. But you need to hit it pretty hard to do some serious damage. And if you did that to a timber or fiberglass boat it will be very seriously damaged. And an aluminum boat may just dent, rather than fracture, so you can head right back home with nothing more to show than a dent, instead of possibly be the subject of a rescue from a sinking boat. And it lasts forever if treated right. If you get a great aluminum fishing boat and treat it well you may well find yourself leaving it to your kids. Because aluminum boats are light for their strength they often need a smaller engine, and the engine is probably the highest cost item. A smaller engine costs less, and uses less fuel. And with a smaller engine they are also lighter and easier to handle. And they require little maintenance. Make sure you hose your boat down after a day out, especially in saltwater, and if you drop a lead sinker make sure you pick it up, as it's not great to leave any other metal in contact with aluminum, otherwise you don't need to do too much maintenance at all. More fishing time. And because aluminum boats last so well they also retain their resale value well. I bought a used aluminum fishing boat 2 years ago and it is currently worth a little more than I paid for it. So there's plenty of good reasons to buy an aluminum fishing boat. Unfortunately they aren't cheap if you want to buy a new boat, but for the same reasons I've mentioned above, it's way better to buy a used aluminum boat, as a used boat is usually much cheaper than a new one, and retains it value well. I would never buy a new aluminum boat. So grab yourself a great used aluminum fishing boat and get fishing this summer, it's the best way to get on the water.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
Boating Logo
26 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
