I need to create my stage name - Computers & Internet
Help--My 101 g8 will not turn on. It just keeps on blinking the Archos name. I have turned it off and on again but stays stuck in that mode???
You have a bad hard drive. Replace it with a new one. You did create recovery disks, right? If not, then you're gonna have to buy a new OS. sorry
Feb 23, 2014 | Archos 101 Internet Tablet
Tip
How to create motion across the screen?
Step 1
Create a small circle to the left in the Stage area. Do this by selecting the circle tool from the left toolbar. Draw the circle in the Stage area.
Step 2
Select the Arrow tool from the left toolbar. Double-click on the circle to select it.
Step 3
Now we have to convert the circle to a symbol. When the circle is converted to a symbol we can create instances of the circle. From the top menu choose Modify > Convert to Symbol. Name the symbol "Ball", and select OK.
Step 4
Go to Frame 10 in the Timeline. Do this by clicking the gray field below 10. Then right click in this field. Choose Insert Keyframe. Keyframes appear as circles in a frame. This operation duplicates the image.
Note: A keyframe specifies changes in an animation. You create keyframes at important points in the Timeline and let Flash create the frames in between.
Step 5
Select the circle and move it to the right a couple of inches.
Step 6
Click on the Timeline any place between Frame 1 and Frame 10. Then right click and choose Create Motion Tween.
Step 7
Choose Control > Test Movie from the top menu to test your Flash movie.
on Aug 11, 2008 | Adobe Flash® CS3 Professional Full Version...
Remove and repair partitions on dell laptop
Boot up with the Windows installation CD start and follow the instructions to install Windows.
Next Delete the existing Windows partitions.
Next Create a new single partition.
Next format this new partition - Format the partition in NTFS not a quick format. This will prepare the Windows for a clean install.
Next create a Username and company name (normally Home is all you need).
Further into the installation, you will be required to put in the Installation code. During the final stages of installation you need to create an User or Users that will use this computer. When you finished installing Windows you need to install the laptop's device drivers. You need to use a computer with Internet access to download these drivers from the laptop manufacturer's WEB site and install these drivers on your laptop.
Oct 20, 2012 | Dell XPS M1210 Notebook
I am using Nokia 5300 xpressmusic with microSD card, my microSD card got blocked and I'm being asked for password which I dunno what, I tried to format it but need the password too, I connect it t
Hi sometimes these kind of problem cause due to the damage of the chip which is in the memory card even if you didn't create any password.This could not be getting repaired at this stage.But if you have created something contact nearest mobile repairing shop.They can generate the password with the help of phone repairing tools.But before visit do not Restore the phone setting by any means.Good luck.Thanks for visiting fixya
Sep 03, 2012 | Nokia Cell Phones
How to install windows xp on probook 4510s
Installing Windows XP
This is generally how your format the hard disk and installWindows.
First you need a Windows XP installation CD and the productinstallation code, which is printed on the Windows label on the bottom of yourlaptop.
Boot up with the Windows installation CD start and follow the instructions toinstall Windows.
Next Delete the existing Windows partition.
Next Create a new partition.
Next format this new partition - Format the partition in NTFS not a quickformat. This will prepare the Windows for a clean install.
Next create a User(name) and company name (normally Home is all you need).
Further into the installation, you will be required to put in the Installationcode.During the final stages of installation you need to createan User or Users that will use this computer.When you finished installing Windows you need to install thelaptop's device drivers. You need to use a computer with Internet access todownload these drivers from the laptop manufacturer's WEB site and installthese drivers on your laptop.
Next connect a LAN cable to the LAN port from your computer to your DSL orcable modem and you need to Activate the Windows installation on the MicrosoftWEB site.
Next up need to upgrade Windows from the Microsoft WEB site including Servicepack.
Next you need to install your programs
Jun 02, 2012 | HP Computers & Internet
I want to format my hp computer
This is generallyhow your format the hard disk and install Windows.
First you need a Windows XP or Windows Vista installation CD and the productinstallation code, which is printed on the Windows label on the bottom of yourlaptop.
Further into the installation, you will be required to put in the Installationcode.During the finalstages of installation you need to create an User or Users that will use thiscomputer.When you finishedinstalling Windows you need to install the laptop's device drivers. You need touse a computer with Internet access to download these drivers from the laptopmanufacturer's WEB site and install these drivers on your laptop.
Dec 25, 2011 | HEWLETT-PACKARD HP 620 WZ260UT Notebook PC...
Why do we need to declare variables?
I'm assuming you are referring to declaring variables in Procedural programming languages such as Java. Variables need to be declared for several different reasons, some of which include helping the computer reserve space in memory for variables to be stored and it also plays a part in the various stages of converting the source code, i.e. the code that you type in VB or Java, into machine code which is a series of binary digits that the computer can actually understand. It helps the computer in debugging the code for errors. In the first stage of code conversion, lexical analysis, information about the variable names is stored. In the next stage, Syntax analysis, the code is checked to be grammatically correct according to the rules of Backus Naur Form, i.e. if a key word such as PRINT is typed in as PLINT the computer will treat this as a variable name and since no information about this variable name has been entered in the lexical analysis stage it knows that an error has been made.
Hope this helps!
Dec 11, 2010 | Computers & Internet
Need some help with ms publisher 2007 Basically I am able to send files to the remote server, and link with Microsoft Publisher, but am not able to publish to the web i created a website in...
A few things you need. Publisher will FTP to your web site ? ?
Who's hosting your site... not your name. If Register.com is your hosting company, you need to check out the settings needed to put into Publisher to FTP (File Transfer Protocol) to your site and the correct name of the main web folder like public_html . You need the login name and password to your web page.
http://office.microsoft.com/en-us/publisher/HA100947601033.aspx
Jul 22, 2009 | Computers & Internet
CRAFTSMAN 7HP 2 STAGE 60GAL. STOPPED CREATING
take the air fiter on pump off and see when pump in running if it has suction if not could have debris under valve keeping it open
Mar 25, 2009 | Air Tools & Compressors
How to creat animation
Hi nana, 1. Create two layers. 2. In the bottom layer, put your ball_mc in the first frame and extend it to occupy 3 frames. 3. In the top layer, add the following code for the first keyframe: gravity=2; bounce=0.9; verticalSpeed=Math.random()*60; 4. Add the following code for the second keyframe: ball_mc._y+=verticalSpeed; if(ball_mc._y+ball_mc._height/2>=Stage.height){ ball_mc._y=Stage.height-ball_mc._height/2; verticalSpeed=-verticalSpeed*bounce; } verticalSpeed=verticalSpeed+gravity; 5. Add the following code for the third keyframe: gotoAndPlay(2);
Sep 18, 2007 | Macromedia Flash MX
Computers & Internet Logo
David Payne
David Payne
