Question about HOW Video Game Consoles & Games
How long will an XBox One last? - HOW Video Game Consoles & Games
What is your mother's maiden name
That is the last name she had when she was a little girl The sam last name as her parents. She lost that last name when she married.
Nov 28, 2013 | Sony Ericsson XPERIA X10 Mini E10i...
Hi, How to format external hard disk whose file system shows as RAW. Under my computer the drive is shown as Drive F but any attempt to open the drive gives an error to format the disk. While attempting...
OK try this
USING DMZ When you enter into your router config window, you need to find the Tab DMZ, it should be under applications and gaming if you are using Linksys. Once you find the DMZ tab, click enable and type in the last digits of your XBOX into the box below. Yes when you do this you are opening all the ports on your Xbox, which is insecure, but show me someone that has hacked into an xbox 360?
<MAKE SURE YOU SAVE SETTINGS>
Using Port Fowarding After you have enabled DMZ, find the Port Fowarding tab, should be under advanced routing. For the name type in XBL or whatever you want, and for port range put 87 to 89, choose UDP, then your XBOX last digits, and enable. Then do 3073 to 3075 choose TCP, then your XBOX last digits, and enable. Then again do 3073 to 3075 choose UDP, then your XBOX last digits, and enable.
after done - then cold reboot both Router and Xbox
XBOX go to the system blade, choose network settings, then test connection. This may take a bit, but when it gets down to NAT type it should say OPEN.
Aug 21, 2010 | Western Digital Passport 320GB External...
Xbox 360 Console: turns red led light on when i turn on xbox 360...
this is a very bad problem. ive had a 360 4 times and still has this problem well im really sorry to tell you but ur 360 is dead. but u can wrap a towel which will probably last ur 360 a good month, then it'll break again. or you could spend a couple bucks to repair and probably last for 5 months. its a 50/50 chance itll last that long
May 16, 2010 | Microsoft Xbox 360 Console
Green screen on Xbox 360
This fault sees to be with a seperate graphics chip which is located at theback of the xbox 360 mainboard. A reflow of this IC chip should sort it.
FixMyConsole
May 18, 2009 | Microsoft Xbox 360 Console
Black Lines show up on my screen from Xbox 360 not T.V.
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. This issue is caused by the video card inside the xbox 360. If you still have warranty better send it in for repairs ( Call xbox customer support )
Good Luck
Apr 02, 2009 | Microsoft Xbox 360 Console
History Log for my Xbox 360 console
well if hes played online you can go to the friends menu and tab over to where it shows previous players and will show you leangth and game played and if its on the new dashboard go to my xbox and the tab next to your avitar it will show the last three games played
Feb 22, 2009 | Microsoft Xbox 360 Console
Xbox 360
Your GPU is failing. There are tiny cracks in one of the solder balls on the GPU that separate when the xbox warms up. If you cannot open it up I suggest you buy a small fan and have it blow directly on the backside of the xbox(the side with the rubber feet). It should keep the GPU cool enough from coming apart. There is no way to tell how long that will last. If you get three red lights on the front of the xbox call 1-800-4MY-XBOX and let them know about your problem. There is a 3 year warranty on your xbox and it will be a free repair if this happens. Good Luck!
Jul 25, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
14 people viewed this question
Top HOW Video Game Consoles & Games Experts
john h
mhder
Level 1 Expert
Person On the...
Level 1 Expert
Are you a HOW Video Game Console and Game Expert? Answer questions, earn points and help others
