How long will an audio receiver last? - Audio Players & Recorders
How do last valid works
Last Valid will use the last valid sound mode for the source selected. If you require further assistance please feel free to email me at or you can call us at 800-229-1687, Thanks, JT
Dec 23, 2015 | Onkyo TX-SR706 Receiver
Have an audio issue with bell expressvu.
It is most likely your dish not your receiver. When is the last time the send receive unit was replaced on the dish? It would probably help considerably to clean off the dish as well.
Feb 03, 2014 | Audio Players & Recorders
No audio. Checked all the basics. Internal fuses are ok. Is this worth fixing?
Check power supply transformer, that could be last thing before deciding to throw it away.
Oct 27, 2013 | Sony Stereo Am Fm Receiver Tuner Amplifier...
I want to connect my cable box to my newly bought toshiba plasma
Is your cable box HD? It would be best for your tv. You can hook up a couple of ways depending on your receiver and tv in/out capabilities. You will always get best picture if you go directly from your cable box out to tv in. You should have capabilty to go HDMI out and perhaps Component out on your cable box. If you can't get hd receiver from cable company. Anyway, if you use HDMI, hook to HDMI out on receiver to HDMI in on tv. HDMI provides audio and video. You can also go componenet(red, blue, green) out from recevier to in on tv. I personally feel component gives you better picture but , doesn't carry audio. For that you need to get audio using either digital optical or, composite cables. You may have to set your HD on receiver through cable boxes menu. The last option is using composite cables(last choice, poorest picture and sound) yellow(video) and red, white(audio)
Apr 04, 2011 | Audio Players & Recorders
Kenwood TS50 - Max volume gives very low audio while receiving
It sound like a bad reostat in the volume control. if its under warranty send unit back to kenwood and have them replace the volume control, and possible speaker involvement.
Jul 12, 2009 | Radio Communications
Having problems with audio on a avr-588 denon receiver
i have the same problem..did you find a solution?
Mar 28, 2009 | Denon AVR588 Receiver
Onkyo TX-DS575 - intermittent audio
You have a problem that was inherent with all Onkyo receivers from this period. You need to contact Onkyo because the microprocessor needs to be replaced. Last I checked, its about $80 from onkyo.
This is NOT an isolated incident as darn near every Onkyo receiver model had this problem.
Good luck...
Nov 15, 2008 | Onkyo TX-DS575 Receiver
No audio from Samsung DTB-H260F
I have a sr605 Onkyo receiver and just hooked it up to a new Mitsubishi 73" and I could not get the picture to work, sound did though. Here is the problem the Onkyo is HDMI 1.3 but TV calls for HDMI 1.3a. There is a big difference between the 2 and the Onkyo will not work with TV. The newer model TV'S say in the manual Category 2 V 1.3a. You need to make sure that all your parts are compatable. It makes a big difference.
Dec 05, 2007 | Mitsubishi HD-6000 DTV Receiver / Video...
14 people viewed this question
