Question about Dryers
How long will a fan last? - Dryers
2000 dodge caravan a/c only blows on the last two fan settings
there is a resister that controls the speeds under the dash next to the fan motor remove it a look at it for burn spots and melted connectors
Aug 15, 2012 | 2000 Dodge Caravan
Have a p50h401. In last week a few times, power
yes you have some few fan in the if they doesnt work it will hover heat thats could from the fan power voltage from the prower supply or the fan it self
you can try an external fan and blow the air on
the back panel in the aeration notch if it stand
thats your problem the circuit came over heat
hope that will help
regards Alan
Jun 07, 2010 | Hitachi P50H401 50 in. Plasma HDTV
How do remove the fan blade from a model fas256n2a
You'll need to turn off the power and remove the top that holds the fan motor on the unit. After you get it out try to clean up the shaft if it's rusty with some sand paper then loosen the set screw on the fan hub. You will probably need some type of puller to get the fan blades off the motor shaft. Let me know if you have questions.
May 24, 2010 | Frigidaire FAS256N2A Air Conditioner
Fan is on but it is not cold could it be the compressor
The evaporator fan motor may be on but not spinning fast enough. They last 4-5 years.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Evaporator fan motor ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Refrigerators
Power went out in house last night. Now the fan
First check where the fan draws power from.
A light switch? Is it on?
Blown fuse, tripped breaker?
Oct 30, 2009 | Hunter Designer's Choice 5-Switchblades Lg...
Hi. my vent made some funny noises last week and
Check the fan blades and see if it's being restricted.Another method is remove the fan blade turn the unit on and see if it spins if it doen'nt tap the motor gently and see if turns.If this works the motor brushes are worn
Sep 28, 2009 | Broan-NuTone N-QT100FL Combination Light...
My whole house fan froze up last hums
Call a professional it sounds like your squirrel cage fan has lost a bearing or broken a support component.
Jul 08, 2009 | Dryers
Inside fan or impeller came apart replaced under warranty
maybe it's the brand of fan that ur using. try buying a different model
Apr 02, 2009 | Ridgid 25648 Wet/Dry Vacuum
Amana bottom refrigerater
huthy, the fact that it's lasting 15 to 20 seconds leads me to believe that it could be one of the fan blades hitting. The valve springs on the compresser would make more of a clunk-clunk noise and wouldn't last that long. The evaporator fan in the freezer compartment has a grille that will snap on and off, clip on the bottom and tabs on the side. See if you can remove the grill and check to see if there is any ice build up around the evap. fan. The other fan, condensor is in back by the compressor, it could be hitting on the shroud upon start up or shut down. Check these things first and post back...Catriver
Mar 20, 2007 | Amana ABB1927DE Bottom Freezer...
Dryers Logo
21 people viewed this question
Top Dryers Experts
