How long will a lamp last? - Televison & Video
How long does a DLP lamp last?
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How long does a DLP lamp last?
The most DLP Television last in between 1000 and 2000 hours this is whit the original lamp and depending on your brand.
Example the Philips lamp last between 6000 to 8000 hours and Osram like 4000 to 6000 hours usually the brand
Some lamps might last only 500 hours while others may last 3000 hours of life so check brand. And keep it clean of dust.
on Jan 27, 2010 | Televison & Video
Toshiba 52hm95 lamp breaks after only weeks of use
It is as far as the set is concerned, it sees the lamp not on.
Most likely cause would be the lamp ballast that drives the lamp.
Dec 20, 2012 | Toshiba 52HM95 52" HDTV Projection...
What is causing the lamp to keep going out on an 82" 837 Mitsubishi TV?
If a OEM Mitsubishi lamp was used you likely have a problem with the Ballast that drives or powers the lamp---the two pin socket for the lamp goes directly to the Ballast.
May 30, 2012 | Mitsubishi WD-82837 82 in. HDTV DLP TV
I have purchased 3 new lamps. one lasted 900 hrs.
Your lamp is rated for 3000 hours. Is the fan working to cool the lamp? When you turn off the projector do you allow the fan to continue to run? If not the lamp is not cooling evenly and the lamp will fail. Th filters should be cleaned regularly and the vents be unobstructed.
May 14, 2010 | Toshiba TLPLMT70 Projector Lamp
Have replaced two lamps in last three weeks.
If you are blowing lamps left and right and the lamp is getting the correct amount of air(Meaning no dust is blocking the vents) I would assume the ballast is the culprit. That is unless you are getting shotty lamps from a vendor who is selling used lamps.
Mar 09, 2010 | Televison & Video
My picture only lasts a few minutes before the screen goes blank but i still have sound if you turn it off then back on the same thing happens
Well for what you're describing it could be 2 things,It sounds like the lamp is acting up on you,basically if you have a generic lamp it could last you from 3500 to 4500 lamp hours and if you have a Phillips lamp that could last you from 6,000 to 8,000 lamp hours,Now if you have already replace the lamp and you still get this problem it could be that your ballast is to weak to power the new can go to they have really good post and videos.
Good luck
Dec 17, 2009 | Samsung Televison & Video
Replacement Mitsubishi lamp busted again in less a year!
A Halogen lamp is a Halogen lamp. They are designed to last between 3000 to 5000 hrs.
You got a much longer life than expected on
the original lamp.
Jul 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Television is now 4 years old, have replaced the lamp 4 times, last time was last week, this lamp lasted three days am waiting for new lamp to see if the last one was faulty. is this a common problem...
Make sure all Airways do not have alot of dust builted up blocking Airways this can cause Lamps to Blow, also keep in mind these sets are only desinged to play between 5000 to 8000 hrs you cannot leave them on day and night like regular TVs,and yes New Lamp does not mean that it was not Defective sometimes companys do have a run as to where they have alot of defective Lamps it Happens
Mar 16, 2009 | Loewe Articos 55 55" Rear Projection...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
