Question about Walkie Talkies Radio Communications
Purchased realtree walkie talkies , they do not work
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
  • 18 Answers
SOURCE: Instruction manual ?
Here is the link for manuals:
http://www.midlandradio.com/owners_manuals.asp
Posted on Feb 04, 2009
SOURCE: One of my tlkr-t3 walkie talkie's will not recieve.
They worked fine the first time we tried them out. Then they were put away for several weeks, and when they've been switched on, one now doesn't send. I checked this by the other putting in scan mode but it doesn't stop scanning at the channel it is assumed to send with. I tried all the channels for sending but neither one is detected. The other way around, so the first one in scanning mode, the 2nd in send mode, works fine (the scanning stops at the channel of the sending one, as expected).
So my conclusion is, that one doesn't send.
I interchanged the (fresh) batteries, but this doesn;t change.
So what could be the problem?
Posted on Jul 30, 2010
eradiostore
  • 1654 Answers
SOURCE: Motorola XTR 446 talkie walkie is not receiving
Try programming the radios without an eliminator code and see if they work together then. If so, there is something wrong with the eliminator code portion of the radio. Also, check your batteries, switch batteries between the units and see if the problem moves to the other unit. It takes more energy to transmit than receive, so a bad or very weak battery could exhibit a similar problem. The radio icon will illuminate whenever a radio is transmitting or receiving. When the radio is in standby mode, the icon should not be shown. Your radio with the icon on all the time may be stuck in transmit. Check your PTT button to see if it is slightly stuck or depressed. Here's a link to the user guide http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103
Best regards.
Posted on Jun 26, 2012
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
Two sets of Motorola Walki Talki radios will not communicate.
In addition to the channel and privacy codes, some Motorola two-way radios have a feature called Eavesdrop Reducer where you have 3 scramble settings available; perhaps you have this set on one of sets of radios but not the other. It should be something like that because otherwise there is no reason that by setting the radios to the same channel and privacy code they wouldn't be able to send/receive to each other.
Nov 24, 2013 | Motorola Walkie Talkie 2-Way Radio
Motorola walkie talkie randomly cuts off
buy professional radios and you get better battery contacts
dont go to work with child's toy
Mar 22, 2012 | Motorola Walkie Talkie 2-Way Radio
Where can I find an authorized repair center for Motorola Walkie Talkies near Pensacola, FL 32505?
I work for the authorized motorola dealer for pensacola, but i work in another branch. Typically we do not service the "walkie talkie" line that motorola makes. For those, you should contact motorola directly. Here is their contact link:
http://www.motorola.com/Consumers/US-EN/Contact-Us/Corporate
Jan 11, 2011 | Motorola Walkie Talkie 2-Way Radio
When i try To walkie-talkie it wont work
They do not have signal to receive the walkie talkie service. Try texting them and telling them to get in an area where they can get better service. Walkie Talkie coverage is very spotty.
Jun 24, 2010 | Motorola Mobility Boost i415 Cellular...
Put batteries in and walkie talkie does not work
either the batterys are duds or the walkie talkie doesnt work- junk or have repaired :)
WE love to help :) and its FREE! so please be kind and thoughtful in your ratings. THANK YOU!
Mar 30, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Nextel i850 can't receive calls
  • may be the walkie talkie can recieve signals only to an certain distance,so it may be due to the signal problem........
  • if the reciever is beyond the permitted distance it loose its frequency...........
  • or else the person who is calling walkie talkie might not hav signal in that area.....
  • and if the walkie talkie does not recieve any signal then the receiver component present inside the walkie talkie might be damaged.........
  • and if it does not reply to an signal transmitter might be damaged..........
  • i hope my answer would be sufficient for u.....thank u......
Sep 10, 2008 | Motorola Mobility i850 Cellular Phone
How do I make it work
It depends on the channels on the walkie talkies.
Can you supply the frz range of the TRC, and walkie talkies make and model and I will try and get the frez on the channels for you.
I can then tell if it will work or not.
Apr 27, 2008 | Computers & Internet
Radio Communications Logo
35 people viewed this question
Top Walkie Talkies Radio Communications Experts
John L radiodude365
Are you a Walkie Talkies Radio Communication Expert? Answer questions, earn points and help others
