Question about Refrigerators
How long will a fridge last? - Refrigerators
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
I need a cooler bag that can last for 10 hours. Where can I get one?
You should get a fridge-to-go tote bag($62 from www.fridge-to-go.com.sg) since it can last 10-12 hours.
May 09, 2013 | Home
I have a Maytag Plus model # MSD2756AEB side by side that has been having isues with the fridge side being warm & not cooling things for the last 3 weeks. Now the freezer has stop keeping things f
HOW OLD IS THE FRIDGE?...WHEN WAS THE LAST TIME YOU PULLED IT OUT AND VACUUMED THE REAR INTAKE AND BOTTOM CONDENSER FINS....THE FRIDGE "HAS" TO BREATH TO OPERATE PROPERLY!!!
*** THE TEMPERATURE SWITCH COULD BE BAD AS WELL
Jul 30, 2012 | Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Fridge works on gas...but not on AC
Your heater should measure 44 ohms, give or take 10%.
95 Ohms is way off. The RM2310 uses a 92 ohm heating element, perhaps you installed / were sold the wrong heating element?
Jul 15, 2010 | Dometic RM2652 Refrigerator
I defrosted the freezer last week and the fridge will not get cold the light in the fridge is working and so is the freezer.
There is nothing that work in the fridge it is just a box everything comes from the freezer. Check if the fan is running this is how the fridge gets its cold air. Check your freezer setting in your fridge. make sure it says warmer fridge. it a door that opens and closes.
Jun 06, 2010 | Refrigerators
Fridge freezer
it seem to me that the gas lewel are low in the system
Jun 16, 2009 | Refrigerators
Door left open, now fridge won't work right.
Shut down the fridge for 10 - 15 Minutes and leave the fridge door open, and push the Defroce button
ANd start the fridge again and after some time check the temp.+ after some time.
Thanking you,
Your Tech Support
Manish Shirsikar,
Fixya.com
May 18, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
