Question about Elna Sewing Machines
My Elna 730 pro. The thread is fraying and breaking.
  • Elna Master
  • 12,241 Answers
Be sure to install a brand new needle that is recommended for the thread and fabric you are using.
Check to make sure the machine is threaded correctly. Remove the thread and rethread from the beginning.
Could be old/bargain bin variety thread. Use only fresh, good quality thread.
Another possibility is an incompatibility of needle, thread, fabric. Make sure the thread is not too small for the needle eye which will cause thread fraying. If the fabric is coarse or dense, it can also cause the thread to fray--a needle with a larger scarf (ie top stitch needle) will help protect the thread during the multiple times the needle pierces the fabric. In rare instances, the needle may be defective or there machine has a burr somewhere that is catching and shredding the thread.
All About Needles
Schmetz Needles Needle Guide
It is important to install brand new needles frequently, ie every 8 hours of sewing. The needle is a very inexpensive item but could be very expensive in frustration, damaged fabric, and possible machine damage.
Posted on May 09, 2017
I have a elna 664 pro overlocker. The thread keeps on breaking. I have even serviced it. It came back. Worked a while and it started doing it again. Works a few stitches and the tread breaks
Hopefully, it was recently serviced. Take it back and have the technician take another look at it. Do NOT unthread it (just clip the threads below the thread tree) when bringing it in so the technician can verify it is threaded correctly and also see where it may be hanging up.
Jan 29, 2018 | Elna Sewing Machines
I have an elna 3210 3230. Thread keeps breaking, stitch does not interlock. Help. Mary Poretta
Sounds like possibly more than one problem.
Why is my thread breaking
https://www.sewhere.com/why-is-my-thread-breaking-how-to-avoid-thread-breakage-at-your-sewing-machine
Sewing Machine Problem 1 Thread Breakage
If the top thread is not picking up the bobbin thread, it's possible the machine has been knocked out of time. Did the needle hit something or break recently? You can search for sewing machine timing or take it for service.
Dec 31, 2017 | Elna Sewing Machines
Elna Pro 4De serger thread breaking
Be sure to thread each in the ORDER specified--for most machines (but yours may differ) upper looper, lower looper, then needles. Follow (closely) the threading diagram on the machine. Missing one guide or hitting the guides out of order will throw you machine into a tizzy! On my serger, the lower looper has to lay over the top of the upper looper/thread before it all gets pulled under the presser foot toward the back of the machine.
It also may help to RAISE the presser foot when threading the machine.
Having problems threading my Elna Pro DE 4 sewing discussion topic...
Threading elna lock pro 4 DE green knob
Oct 06, 2017 | Elna Sewing Machines
What are the correct settings for basteing on an elna excellence 730
Here's a manual for your machine:
ELNA eXcellence 730 Instruction Manual
If your machine does not have a "basting" stitch selection, you make your own basting stitch by:
* Setting the stitch length to the maximum
* Loosen the upper tension so the bobbin thread lies flat under the fabric
Then to gather or remove the basting stitch, it is easy to pull on the bobbin thread.
Mar 12, 2017 | Elna Sewing Machines
I have an Elna Pro 4 DE overlocker and the thread keep breaking - I have re threaded a number of times now but the thread keeps breaking - it was working fine earlier today - what could be the proble
Try different thread (black thread seems to be more problematic because of the heavy dye). Perhaps, change the needles.
When you re-thread, do you completely remove all the thread and start from the beginning--there could be a snag somewhere or the thread is looped around something, ie the thread tree? ALWAYS RAISE the presser foot when threading. Give each thread an extra little tug when going through the tension disk--it will sometimes make a little snap sound when it seats. Also, make sure you are threading each in the order specified. Threading out of order will generally guarantee a problem.
There is a slight chance something (thread bits, lint) could be stuck in the tension disk.
If it continues, you may want to take it for service as it could be the timing is off.
Dec 12, 2016 | Elna Sewing Machines
When this happened to me I was told the thread was old. Sure enough, it was old thread and now that I've replaced that old (20+ year) thread all is fine.
Jun 07, 2013 | Elna 7200 Pro Computerized Sewing Machine
I have an elna overlock Pro 5DC, which I bought new years ago. The dealer went out of business, and with her the repairman who knew Elnas. When mine developed a problem, I had it serviced by an all-brand...
If you google elna overlock pro 5dc, I found this site and you can download your manual for $10, hopefully it will help you.http://www.tradebit.com/filedetail.php/30251842-elna-pro-5-dcde-sewing-machine-owner
It is so frustrating to have a great machine and no one can help you. Good luck
Sep 21, 2010 | Elna Sewing Machines
Thread frays and breaks when sewing and embroidering.
Make sure that the machine is threaded correctly, that the needle is in properly, that the bobbin case and bobbin are both inserted correctly and that you are not using old thread.
Make sure that there is a new needle in the machine and loosen the top tension about a number
You need to carefully re-thread the machine.
Aug 03, 2009 | Janome Memory Craft 9000 Computerized...
My lower looper thread keep breaking, what is the problem.
Feb 17, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
37 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
