Question about The Health & Beauty
What are the symptoms of an overdose of vitamin D?
Is it okay to take vitamin D 50,000UNIT and Multivitamin together?
fixya site is not a medical forum so if you want a second opinion see another doctor
however vitamin D is from the sun and it is possible to overdose and poison your self with vitamin D if taken as a pill
Nov 04, 2017 | The Health & Beauty
WHAT SHOULD BE DONE FOR AN OVERDOSE OF ESTROGEN
Hi @PENELOPE KEYSER , please consult your doctor ASAP. See overdose symptoms on this link below. Be safe!
Estrogen overdose MedlinePlus Medical Encyclopedia
Nov 01, 2017 | Washing Machines
Can drinking lots of water lessen the effect of excessive amount of Tums?
Overdose If someone has overdosed and has serious symptoms such as passing out or trouble breathing, call 911. Otherwise, call a poison control center right away. US residents can call their local poison control center at 1-800-222-1222. Canada residents can call a provincial poison control center. Symptoms of overdose may include: nausea/vomiting, loss of appetite, mental/mood changes, headache, weakness, dizziness.
Feb 23, 2017 | The Health & Beauty
Can zink make you constipated:-
Yes it can.
Constipation Due to Zinc Overdoses ' LIVESTRONG.COM
www.livestrong.com > Diseases and Conditions
  1. Cached
  2. Similar
Jul 24, 2015 - While constipation and other abdominal upset symptoms can be temporary effects associated with zinc overdose, continuing to take excess amounts of supplements can cause you to experience a copper deficiency.
Are zinc supplements causing constipation? - Thyroid UK ...
https://healthunlocked.com/.../are-zinc-supplements-causing-constipation
  1. Cached
  2. Similar
May 18, 2015 - I started taking a fairly low dose zinc supplement... ... Zinc can cause constipation, but not usualy at the dose you're on. It would be more likely ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Zinc Safety - Mayo Clinic
www.mayoclinic.org/drugs-supplements/zinc/safety/hrb-20060638
  1. Cached
  2. Similar
Zinc may cause anorexia, asthma-related symptoms, blood disorders, changes in attention, changes in copper metabolism, changes in iron levels, changes in skin pigmentation, changes in thyroid function, changes in zinc levels, bad or different taste, bloating, changes in cholesterol levels, constipation, decreased zinc ...
ZINC: Uses, Side Effects, Interactions and Warnings - WebMD
www.webmd.com/vitamins.../ingredientmono-982-zinc.aspx?...982
  1. Cached
  2. Similar
The concentration of cadmium in zinc-containing supplements can vary as ... Zinc deficiency can alter vision, and severe deficiency can cause changes in the ..... or other qualified health care provider because of something you have read on ... Knee Treatment Plan · Hodgkin Lymphoma Treatment · Frequent Constipation?
May 03, 2016 | Health & Beauty
My children had a change in taste buds when they ate their meal. When they drank water throughout the day they had pain follow.
You should discontinue this over the counter vitamin regimen until all symptoms subside before considering restarting with a lesser dosage. Vitamins for people of all ages can sometimes exceed 100% for a given day's recommended total. When you combine this with the amount taken in through normal diet, for instance Calcium gained by drinking milk plus Calcium in the vitamin, you can risk an overdose on the vitamin. Overdose can occur with anything and this will pose certain dangers to children as they grow. While it is admirable to desire to provide children with all the vitamins and nutrients they require to grow, one must be careful not to over-do it, as the saying goes with too much of a good thing.
Nov 21, 2013 | Natures Plus Animal Parade Gold Assorted...
Can I mix two different pre-workout supplements together?
It is not the best idea to mix two together because then you'll probably consume way too much caffeine. Also, many pre-workout supplements contain similar ingredients so if you don't feel like the recommended serving is strong enough, you can always add a serving or simply try a different product.
Feb 04, 2013 | Health & Beauty
I would like to start and take a multi-vitamin. Should I worry of having any side effects?
Multi-vitamins are very safe, especially if you buy it from a high quality brand such as Centrum and GNC. Of course, large amount (especially if you overdose) of different vitamins or minerals could cause some side effects:
Too much iron can cause gastrointestinal problems such as heartburn and upset stomach.
Stimulating vitamins taken before sleep can cause sleeping issues.
Too much Potassium and calcium can cause upset stomachs.
Too much magnesium will make you have diarrhea.
What vitamins are important for hair health?
Hair fall problems are the most common nowadays. Hair falls occurs due to lack of vitamins in our body.
The vitamins which are essential for hair health described below
1.Vitamin B3: found in fish such as tuna and salmon, poultry (chicken and turkey), roasted peanuts and mushrooms.
2.Vitamin C: Sweet red peppers, guavas and dark green leafy kale contain very high amounts of Vitamin C.
3.Vitamin B7: Dark leafy green Swiss chard, carrots, and nuts including almonds and walnuts, are all naturally high in Vitamin B7.
What is the 2 classification of vitamin
Fat soluble vitamins
These vitamins are soluble in fats, oils and in fat solvents like alcohol, etc. There are four fat soluble vitamins. They are: Vitamin A, Vitamin D, Vitamin E and Vitamin K.
These vitamins are stored in liver and are not readily excreted in urine and are not absorbed in the body unless fat digestion and absorption proceed normally. Among all the four vitamins only Vitamin K has a specific coenzyme function. Fat soluble vitamins are made up of one or more carbon units and hence they are called Isoprenoid compounds.Their deficiency can cause malabsorptive disease.
Excess intake of these vitamins may cause hyper vitaminoses. Water soluble vitamins
These vitamins are soluble in water. They are again divided into B complex vitamins and non B complex vitamins. B-complex vitamins are - Thiamine (B1), Riboflavine (B2), Niacin (B3), Pyridoxine (B6), Biotin (B7), pantothenic acid, Folic acid and Cyanocobalamine (B12). Vitamin C is the non-B complex vitamin.
These vitamins are not stored in the body (except B12). Hence, they are to be continuously supplied in the diet. The biochemical reactions of these vitamins is through co-enzymes. The common deficiency symptoms of these vitamins are Dermatitis, glossitis, diarrhea, depression, etc.
Jul 12, 2011 | Computers & Internet
What is the vitamins of the brain
Here are descriptions of the main types of vitamins that can affect memory and brain power:
  1. B Vitamins. Research shows that B vitamins improve memory by creating a protective shield for the neurons in the brain. B vitamins break down homocysteine, which is an amino acid that is a toxic poison to nerve cells. These vitamins also aid in the production of red blood cells, which carry oxygen, an important brain nutrient.The most important B vitamins for memory include B6, B12, and Folic Acid (B9). You can increase the B vitamins in your diet by taking vitamin supplements and by consuming healthy, natural foods such as spinach and other dark, leafy greens; broccoli, asparagus, strawberries, melons, black beans, leeks, and other legumes, citrus fruits such as oranges and grapefruit, and soybeans.
  2. Antioxidants. Vitamins C, E, and beta carotene are antioxidants and are also important vitamins for memory. Antioxidants protect brain tissue by breaking down free radicals, which are toxic forms of the oxygen molecule natually found in the bloodstream. Antioxidant vitamins and memory are linked because the damage free radicals do can impare the functioning of the neurons in your brain. Like the B vitamins, in other words, the antioxidant vitamins prevent damage to the basic brain structures.
    Supplementing with antioxidant vitamins daily is recommended. In addition, these vitamins can be found in naturally occurring foods such as blueberries, strawberries, and other berries; sweet potatoes; red tomatoes, spinach, broccoli, green tea and other types of tea, nuts and seeds, and citrus fruits such as oranges and grapefruits.
    Note that with some of these foods, you get both the B vitamins and the antioxidants - a double dose of vitamins for memory improvement!
  3. Omega-3 Fatty Acids. Omega-3 fatty acids are not really "vitamins" as such, but important fat molecules that enhance memory and brain function. So much is said about so-called bad fats, but the Omega-3 fatty acids are actually a class of good fats. These fats help protect the brain against inflammation and high cholesterol. That's what makes these fatty acids good vitamins for memory improvement.
Jun 26, 2011 | Health & Beauty
Health & Beauty Logo
26 people viewed this question
Top The Health & Beauty Experts
Motshidisimary
Motshidisimary
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
