Question about Cub Cadet Garden
I have a 2004 cub cadet 1040 riding lawn mower. New battery, charge it up and it will start. If I get off, it automatically quits and won't even turn over until I charge again. Please advise.
SOURCE: riding lawnmower starts but will not continue stay running?
its probably in your ingnition switch, grab the switch and turn it right the turn key I had the same problem and that fixed it. It also wasnt starting and it was the same problem the switch is lose.
Posted on May 31, 2009
  • 7 Answers
SOURCE: cub cadet lawn mower won't
What have you changed?? What model lawn mower is it? Is it a riding lawn mower or a push lawn mower? Does it turn over(engine turning with the starter), or does it do nothing when you turn the key over? I have serviced cub cadets for almost 20 years, from the very first model(1959) to present, and i own 13 different tractors myself. if anyone can help you, i should be able too. i just need more info about the unit and its problems. i look forward to helping you.... -Brian-
Posted on Nov 07, 2010
  • 2239 Answers
SOURCE: Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Posted on Mar 07, 2012
BAMOUT
  • 2478 Answers
SOURCE: need wiring diagram for cub cadet lawn mower lt1045
Posted on Mar 15, 2012
  • 21 Answers
SOURCE: i need the drive belt diagram of the cub cadet
3 yrs later.
To find belt diagram, Look for a diagram sticker underneath the driver side foot rest. (faces the ground). Goodluck people.
Posted on Jun 13, 2013
How do i replace v belt on ltx 1040 cub cadet.
Nolan, Check the attached links,instruction and guides for belt replacement on Cub Cadet. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change the Deck Belt on Cub Cadet Riding Lawn Mower Using Model...
How To Install or Replace Drive Belt on Lawn Mower Cub Cadet
How to Change the PTO Belt on Cub Cadet Riding Lawn Mower
cub cadet belt replacement diagram Google Search
Jun 30, 2016 | Garden
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
www.youtube.com/watch?v=XLT1v7h4at4
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
Cub cadet ltx 1040 neutral adjustment
if trator is creeping bad check valves replace them
May 23, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Sold wrong battery and crossed terminals
I doubt that jim, but i don't know anyway quicker to kill a charged battery than to hook it up backwards to another battery (sparks you mentioned) try using a spare car light bulb to verify that battery is charged up , also look for inline fuse someplace close to the battery location, you might have blown that , continue using car bulb to "walk" thru circuit to verify presants of voltage (key/starter/dashlghts)
Apr 16, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub cadet 1000 series LTX 1040 riding lawn mower
Check the pully alignments with a straight edge. Make sure the belt is tight.
May 19, 2013 | Cub Cadet Lawn Mower V belt Replaces CUB...
Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
May 12, 2012 | Cub Cadet Garden
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
23 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
