Question about Cameras
Is there a way to charge my Canon T6S camera via USB?
Do I need to physically remove the battery and use the dedicated charging cradle or can I use a mobile battery pack and charge via USB mini?
  • Cameras Master
  • 3,997 Answers
AFAIK, the power drain will be so great it can only charge via the cradle.
Posted on May 09, 2017
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
Battery exhausted message no battery charged
The manual says:
Confirm all connections.
Off is selected for Charge by computer in the setup menu.
When charging by connecting the camera to a computer, battery charging stops when the camera is turned off.
When charging by connecting the camera to a computer, battery charging stops if the computer is suspended (sleeping), and the camera may turn off.
Depending upon computer specifications, settings, and status, it may be impossible to charge the battery inserted into the camera via computer connection.
So be sure you are charging the correct way. Best way to do is to remove the battery and put it on the charger for a couple of hours. If you have the battery out, you can check all connections of battery and in the camera.
In trouble shooting, more than a full page is dedicated only to the battery and the method of charging. The manual is still online, but should also on the CD you got with the camera.
Nov 16, 2013 | Nikon Coolpix 3200 Digital Camera
Is there a way to charge and USB connect Casio EXILIM EX-S500 without using a USB cradle?
Yes to the first and why bother to the second.
You can charge the battery outside the camera using a BC-10L charger or equivalent. One such charger is available here.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Oct 20, 2012 | Casio Exilim EX-S500 Digital Camera
Can I charge a Casio Exilim battery throug USB to my PC
No. The EX-Z60 does not charge the battery through the USB port. You need to use the supplied charger. Alternatively, if you have the EX-Z60DX cradle, you can plug the camera into the cradle and plug the cradle into a wall outlet. However, using the cradle will not let you charge the camera through the USB port either.
Aug 23, 2011 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Hi am I able to charge my canonsx210is on a usb car charger
Most, if not all, Canon point and shoot cameras DO NOT have a capability of charging through the USB port. If using rechargeable batteries, The battery(s) have to be physically removed from the camera and placed in an external charger.
Jul 02, 2011 | Canon PowerShot SX210 IS Digital Camera
It shut down
Try removing the battery and charging it in the charging cradle. If the camera does not turn on after you have charged the battery, it may be that the battery does not hold a charge (you can test this with a simple globe test light).
If this is the case, just go and buy a new battery and charge it fully before using.
Feb 22, 2011 | Canon PowerShot SD1300 IS IXUS 105...
I have a Canon Ixus 95015 but I have mis-placed the charger. Will the lead that connects to my computer to view the pictures I've taken charge the battery? Or will any Canon Ixus charger fit my camera?...
You can find a new charger by searching for your camera's model number (add the word "charger") on Amazon, but it might be better to get one of the "universal" chargers instead. There are several makes of these, that will charge any of the small lithium batteries used in cameras and phones, so you won't have this problem again. And the universal chargers are often cheaper than the ones dedicated to a single battery type.
If your camera came with a charger for the battery, then it is unlikely that it will charge from the USB lead.
Dec 20, 2010 | Canon PowerShot S500 IXUS 500 Digital...
Camera will power-up only when connected to DC
This from Sony website:
To ensure the proper operation of the battery, please do as follows after charging the battery.
(1) When charging by connecting the AC adaptor directly to the camera Pleasedisconnect DC IN from the camera after charging is completed. Also, itis recommended to remove the battery from the camera when charging iscompleted as the battery is discharged slightly even if the camera isturned off.
(2) When charging with the supplied USB cradle Ifthe camera is installed in the USB cradle, please leave the power cordconnected to the outlet (when using the power strip, please leave itsswitch to on).If you want to unplug the power cord (or switch off thepower strip) after the battery has been charged using the USB cradle,please remove the camera from the USB cradle. Also, it is recommendedto remove the battery from the camera when charging is completed as thebattery is discharged slightly even if the camera is turned off.
NOTE: When you charge the battery by connecting the AC adaptor directly tothe camera or using the USB cradle, do not leave it with the power corddisconnected from the outlet.
Should it not work, continue with the manual reset procedure below:
  1. Turn off the camera.
  2. Ensure the camera is not connected to an AC power adapter.
  3. Remove the battery from the camera for 15 seconds.
  4. Reinsert the battery.
  5. Turn on the camera.
NOTE: If the issue is not resolved by performing a reset procedure, service may be required .
Oct 09, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
Battery charging
i have not used my camera since June, when i went to charge the battery the other night the Red light just kept flashing even after leaving it for 8 hours, i can get pictures from it which are stored in it but the shutter will not open whilist in and out of the cradle.
May 28, 2008 | Casio Exilim EX-S880 Digital Camera
Cameras Logo
73 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
