Jura error 10
I have problem with Jura error 10 and i search online, it saids THE HALL SENSOR ON THE LEFT GRINDER FAILED. how to fix?
2 Suggested Answers
  • 5631 Answers
SOURCE: Jura Impressa s9. Why does it display a fill bean error?
Maybe reading the user's manual you can have a hint?
Download it from
http://www.ooo.jura.com/home_ooo_x/service_support/download_manual_jura_impressa_s9notc_english.pdf
Posted on May 15, 2015
How to fix Saeco Primea's error 1 problem ?
OK you are doing the right thing but having done all this did you see if you have a break in the print or foulty cable or may be a foulty PCB
May 09, 2016 | Saeco Coffee Makers & Espresso Machines
Jura error 2
Hi, I made a video how to fix your Jura step by step, good luck,,,
http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Nov 17, 2013 | Jura Saws
Hi i have a jura j9 and the grinder got stuck ,i
http://www.ehow.com/how_5121955_troubleshoot-saeco-espresso-machine.html I am afraid that this is the only help I can offer you at this time.
Sep 12, 2013 | Saeco Magic De Luxe Espresso Machine
I have a 15 ton carrier gas pack at work with inducer motor and spark igniter with hall senser ..showed error 6 flashes on igc board which the drawing said was inducer motor or hall senser...
The error code is always right. Sometimes misleading, but in 15+ yrs I've seen, always right. I'm not familiar with a Hall Sensor. If this is a remote sensor, as in a remote location that senses in the hall and not at the tstat then I know what you're calling a hall sensor. Make sure your IDM is working and closing the air proving switch. And that no other safeties are in that circuit. Check continuity to the remote sensor wiring and all connections? I've seen hot surface ignitors look fine and not work, but pulled a new off the truck and the new worked. All else fails, remote sensors are tough to get a good ohm value due to a temp difference affecting the ohms, replace it. I'm not sure why your "drawing" would relate the IDM to a remote sensor so I'd focus on the IDM and follow the voltage trail.
Apr 03, 2017 | Carrier Heating & Cooling
Jura Capresso E8 keeps getting error code 8 over and over. I will clean, remove grounds etc, it will make a few espressos, then back to the error code. I can hear it struggling.
One of the problems that I see with these units is the Grinder setting. Sometimes the grinder is set too fine for Dark and Oily beans. This setting will ( can) clog up the brew screen after less than 10 cups are brewed. Also, running the cleaning tablets through to create a clean starting point may help you. Try turning the grinder to a slightly coarser setting and try that.
Sep 21, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura F70 Grinder stopped working
The switch or photo sensor is not sensing any beans present.
So it can't continue
Use torch to inspect bean entry area
Small brush etc
Apr 18, 2010 | Jura Capresso Coffee Makers & Espresso...
Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Aug 14, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
