Question about Hobart Dishwashers
I have a Hobart c44a dishmachine unit is not auto filling ?
3 Suggested Answers
  • 68 Answers
SOURCE: dishmachine won't fill
Your problem is as straightforward as your observation, the unit is not getting enough water flow.
First, if your DW water is hooked up with a braided stainless hose, there is usually a screen in the end of it, (check both ends). It gets clogged with debris and chokes off the water. Make sure the line is not kinked.
If that doesn't work, you are likely having trouble with your fill valve. It is under the front kick panel. It has a large castle like upper cap. It is common for debris in the water to make this valve malfunction. It isn't too difficult to open up without removing. Just watch how it is assembled. If you pay attention, it's easy. If you have a booster, the hoses are very brittle with age.
And otherwise, the fill valve may be bad. REMEMBER, verify your supply water flow where it connects to the machine first. Don't assume. You could have a pressure regulator or a line strainer that is part of your supply line. They do fail. But that's a plumber's fix, not a technician.
Posted on Jun 21, 2008
rickead1
  • 1998 Answers
SOURCE: I need the wiring diagram
there are some electrical diagrams located inside the manual of the machine http://www.instawares.com/Prod_PDF/HOB-C44A263.pdf if your looking for the entire wireing schematic for the whole machine on the top of that link gives hobarts number 1-888-4hobart if you have any further questions message me back Thanks Rick
p.s here is another manual as well with troubleshooting tips towards the end http://hobart.co.kr/install_pdf/037.pdf usually the lid to the control box also has the diagram but you stated that that was wiped off so try the first link and if that isnt enough information then call hobart directly and they would be more then happy to send you the schematic Thanks again Rick
Posted on Mar 01, 2011
Hobart dishwasher overflowing it is a c44a in manual it continues to add water when running
If it continues to put water in machine when switched off then fill solenoid, if not then possibly level sensor
Jan 22, 2018 | Hobart Dishwashers
I have a C44A dishmachine that will not time out and shut off after the last basket is thru. In auto mode.
could be damage on this parts:
-Manual/auto switch
-solid state timer or electronic board
-inlet reed switch
Dec 11, 2015 | Hobart Dishwashers
How Do I fill the dishwasher with water to first start it
Close the front access door and turn on the power switch. It should automatically fill.
Oct 02, 2014 | Hobart C44a Commercial Dishwasher
Rinse temp not high enough on hobart c44a dishwasher
If your water temp. gauge (on piping) is showing 180 but the digital display is only reading 125 deg. then I would remove the water temp sensor from the rinse piping on back upper part of machine (It is a small probe with wires coming out of it). Clean probe with emery cloth and put it back in to see if that changes the display. If it doesn't then you may need to replace the probe.
Aug 19, 2014 | Hobart C44a Commercial Dishwasher
I need a wire diagram for a hobart C44A
The lid to control box has diagram inside, the heat kw is in the metal ID plate on right end of top of control box
Oct 24, 2009 | Hobart Dishwashers
Dishmachine won't fill
Jun 19, 2008 | Hobart 24 in. LXIC-5 Built-in Dishwasher
I have a hobart dishmachine model# CRS-66AW after filling dishmachine water will not stay in the wash tank, sometimes half of the water drains out. we have replaced the o-rings on the drain plug recently....
Which tank is loosing water?
Number 1. Make sure all curtains inside are in place.Curtains help keep the water in the proper tank. For example, curtains are missing between prewash tank and wash tank, the wash tank water could be significantly splashing into prewash tank and out the p.w. tank overflow. Are you ruling out the drain because you replaced o-rings? Look at the floor drain as machine is running. Do you see a large flow of water going down drain? There is a drain heigth adjustment on the drain lift. Mabe the drain stopper is not dropping far enough.
Mike
Mar 07, 2008 | Dishwashers
Dishwashers Logo
60 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
